Leak Repair & Best Way to Attach Modifications - Page 2 - Fiberglass RV
Old 11-16-2009, 06:22 PM   #15
Be very careful using anything metal to remove silicone. You can do an effective job with a plastic (non-serrated) knife or plexiglass ice scraper. Neither will mar the gel-coat (unless you use a pointed edge and gouge at the silicone).
Old 11-16-2009, 09:57 PM   #16
Raya's Avatar
Good point, Donna.
Or, if you do use a metal tool, then one trick is to round off the outside corners; that way it will be much less likely to "dig" in.
Raya
Attach small windows with bolts? Amy M Problem Solving | Owners Helping Owners 13 04-04-2012 05:54 AM
Attach a Screen Room to Boler, Adhesive Velcro GordM Care and Feeding of Molded Fiberglass Trailers 15 06-16-2010 07:21 PM
HOW DO I RE-ATTACH BELLY BAND Mary Lynn K. Problem Solving | Owners Helping Owners 19 05-30-2006 05:38 PM
How did you attach your sway bar? Chris Z Problem Solving | Owners Helping Owners 9 04-11-2006 06:59 PM
Modifications Legacy Posts Modifications, Alterations and Updates 6 04-19-2003 05:29 AM
