leaking window - Fiberglass RV
Old 10-07-2019, 05:10 PM   #1
Trailer: scamp
leaking window
finally removed a window with very rusted screws, did what was needed & put it back in the wall. Only trouble is, the window is not original & whoever enlarged the hole made it too big. From the outside the window looks like it fits however from the inside without the frame, I can see it barely touches the fiberglass in a couple places.
So, what do you think would work well to keep it in place? Do I pack the gaps with more tape, use the 3M caulk, house window foam, shape little wooden filler bits, ?????
JudyG is offline   Reply With Quote
Old 10-07-2019, 06:29 PM   #2
As long as the outside frame has adequate coverage, it would be a simple thing to fabricate a flange for the inside from sheet metal held firmly in place by the original inside frame... or make a whole new inside frame from oak using the same method to attach it to the outer frame.
Old 10-07-2019, 07:10 PM   #3
Trailer: scamp
Thanks, those are both ideas I didn't consider.
Window leaking between glass and screen B-Rock Problem Solving | Owners Helping Owners 7 06-15-2013 09:25 PM
Leaking emergency window on Trillium 55goddess Problem Solving | Owners Helping Owners 15 11-16-2012 11:12 AM
Window Gasket Still leaking after replacement Ryan P R Problem Solving | Owners Helping Owners 9 10-08-2012 05:43 PM
Leaking window... cpaharley2008 Problem Solving | Owners Helping Owners 9 06-12-2011 01:53 PM
leaking window Heath G. Problem Solving | Owners Helping Owners 10 06-21-2009 04:16 PM
