leaking window help - Fiberglass RV
Old 11-08-2015, 09:23 PM   #1
Trailer: Chez Nous - a 2011 Scamp 16'
leaking window help
hey gang. I'm in oregon where it continues to rain a LOT. Discovered a small leak in the drivers side back window on my scamp 16. Putting a chunk of paper towel in the inside narrow track the window sits in absorbs the water for 8 plus hours. This is not a catastrophic leak (yet anyway) so I'd like to put a bead of some kind of dappish product around the outside of the window to see if this stops the leak for now. What NON silicone product would work best for this? Thanks.
Sharon
SharonM is offline   Reply With Quote
Old 11-08-2015, 09:41 PM   #2
Check the weep holes on the outside to be sure they are clean so any water against the glass drains away. There may be covers over them but I doubt it. I use weed wacker string to clean them out
Old 11-08-2015, 09:45 PM   #3
OOOOH, great idea. Didn't think of that. Supposedly rain will stop a few hours tomorrow morning and I will check then, cuz I sure can't see WHERE the water is coming from on the inside. Thx for that, Bob.
Old 11-09-2015, 10:28 AM   #4
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
If the channels and weep holes are really filled up with dirt, you may want to remove the sliding pane to clean them. We had a very recent thread on that subject and I posted how to do it. Here it is:Leaking windows
Old 11-09-2015, 11:06 AM   #5
Kai in Seattle's Avatar
Been searching FGRV for what product to use on the amerigo windows that are leaking...they're like Trillium windows in that they tip out at the bottom, but are one solid piece of plexiglass, not the little louvers. IF the trim edges need caulked, would automotive windshield material work? (Don't think we've found any weep holes, though Paul has been looking.)
And--for my info, what's wrong with silicone? (Not that we're planning to use it...) Just haven't been able to find the threads about it.
Old 11-09-2015, 11:28 AM   #6
The info is hiding in plain sight...
Why is silicone bad?
Old 11-09-2015, 12:26 PM   #7
Thanks--like most internet issues, one has to know the exact magic phrase. Be only a few words off, and no dice.
Close only counts in hand grenades and horseshoes.
GREAT help, LOTS of info, of course our windows were sealed with silicone by the PO, which explains the leaks. NOW we have to check the little roof vent and the fantastic fan.
thanks again!
Old 11-09-2015, 08:58 PM   #8
Trailer: UHaul
Don't use silicone. It will leak in no time again...and it is horrible to remove. If you need a bead, use butyl caulking ( or gutter caulking).
Annette in NC is offline   Reply With Quote
Old 11-09-2015, 09:25 PM   #9
Silicone! OMG I hate that crap on the exterior of any all-molded-towable. THIS is NOT my trailer but check out all the CRAP someone applied to a window on a U-Haul trying to stop the leaks. I scooped this picture from a U-Haul Facebook page that I'm a member. ALL that silicone and the window STILL leaks. Now the owner has a huge problem removing that Devil's Bane.
Old 11-10-2015, 07:39 AM   #10
Thanks--like most internet issues, one has to know the exact magic phrase. Be only a few words off, and no dice...
Kai, the built-in search function is pretty useless (like you say, you have to hit the exact phrase), but the Google site search is much more sophisticated. It's only available on the website, not on the app. Go to the blue bar under your log-in information, "Search," and go to the bottom of the drop-down menu "Site Search/Google."
Old 11-10-2015, 02:20 PM   #11
WOW, thanks! Yes, it works great! Now if I could only remember the latest thing I wanted to find out about on FGRV! Oh, well, it'll come back sooner or later. Thank you again! BIG improvement!
Old 11-12-2015, 02:12 AM   #12
Trailer: 1985 BigFoot G
Mississippi
I was going to ask about pulling the windows out of my 85 camper and replacing the seal around all of them. I bought butyl rubber seal stuff. I want to do every one of them. I've watched a video online about how to do it but wondering if there is any secrets to getting it done right? Figured some of you have done it. Since it's getting cooler now I want to get started working on ours again and need to get these windows done!!!
Do we also need to run a bead of pro flex I believe it's called around them once we get them back in? Or just do the top edge part?
Gardnpondr is offline   Reply With Quote
Old 11-12-2015, 03:05 AM   #13
Borrego Dave's Avatar
Clean the surfaces up good for the new butyl, no Pro Flex is needed anywhere. The butyl is a bit easier to use if it's warm. Once you set the window in place tighten the screws a bit at a time like you would torque an engine head to let the butyl have time ooze. There is no PSI to go by, stop when it seems nice and tight. Pop rivets are the same. With my gun it seems to take three grips per rivet before it pops. I use half pulls between rivet rounds to let the butyl do its thing. BTW, if you're installing anything of plastic with rivets like vents and such, running the first down to popping by itself is asking for a broken/cracked item .
Old 11-13-2015, 04:54 PM   #14
Trailer: 1973 Love Bug '13
Sharon, if it is a leak between the gasket and the plexiglass, you may try this. We have had great success using this product.
Captain trolleys creeping crack sealant. Cant take credit for this information. Someone on this forum put us on to it.
http://www.amazon.co.uk/CAPTAIN-TOLL...A2EMKVSX8TAEXI
Cat futrell is offline   Reply With Quote
Window leaking between glass and screen B-Rock Problem Solving | Owners Helping Owners 7 06-15-2013 09:25 PM
Leaking emergency window on Trillium 55goddess Problem Solving | Owners Helping Owners 15 11-16-2012 11:12 AM
Window Gasket Still leaking after replacement Ryan P R Problem Solving | Owners Helping Owners 9 10-08-2012 05:43 PM
Leaking window... cpaharley2008 Problem Solving | Owners Helping Owners 9 06-12-2011 01:53 PM
leaking window Heath G. Problem Solving | Owners Helping Owners 10 06-21-2009 04:16 PM
