Leaking windows - Fiberglass RV
Old 02-16-2009, 07:50 AM   #1
Trailer: U-Haul
I am very happy to be a new member of your group.
I have a 1986 13 ft U_Haul trailer and almost all my windows are leaking.
What can I do to fix them or where can I by new ones?
Hélène from Montréal
Hélène L is offline   Reply With Quote
Old 02-17-2009, 01:06 PM   #2
Lizbeth's Avatar
It depends on what is leaking. The window itself or the installation of the window to the trailer. If it's the window there are repair parts available for most windows. If it the install they will need to be removed and properly reinstalled.
There is info on this site about window fixing. Do a search on window repair or installation.
Old 02-17-2009, 01:35 PM   #3
Daniel V.'s Avatar
Trailer: '74 Trillium 1300
I'm not familiar with U-hauls, but as Lizbeth pointed out, it depends if your windows are leaking around the outside frame, or within the panes themselves. Layers of silicone sealant around the outside frame, for example, are a clue that there could have been long-term leakage that was just masked by a previous owner. The right way to fix this is most likely to remove all silicone, remove the window, then reinstall it using butyl tape, and you should be good to go for another 20 years.
Daniel V. is offline   Reply With Quote
Old 02-17-2009, 05:01 PM   #4
Raya's Avatar
I didn't reply earlier because I feel like I remember that the U-haul side windows use a rubber gasket instead of a flange that you'd use butyl tape on. Helene, can you post a photograph of the windows in question? (Or even find one on the web that looks like yours, so we can see.)
Raya
Old 02-17-2009, 05:51 PM   #5
Look for weep holes on the outside bottom of the windows to make sure they are open. This only applies to metal frames. If the weep holes get plugged up some water may enter the window.
Could it be possible that you have condensation on the inside of the glass? If the camper is airtight and people are in it, it creates condensation on the inside.
windows
Leaking Windows Carolyn Patterson Problem Solving | Owners Helping Owners 1 10-03-2007 03:24 AM
Leaking windows? Lenna F Problem Solving | Owners Helping Owners 3 09-20-2007 02:36 PM
Leaking windows Stephen Brown Problem Solving | Owners Helping Owners 29 08-04-2007 02:31 PM
Leaking windows GrahamD Problem Solving | Owners Helping Owners 1 07-15-2006 05:39 PM
leaking windows Legacy Posts Problem Solving | Owners Helping Owners 32 12-19-2002 04:38 AM
