Leaks - Fiberglass RV
Old 08-14-2019, 09:10 PM   #1
Trailer: Trillium 4500
Leaks
We have water sitting below one of the dinette benches of our trillium 4500. Any recommendations as to where to look for the leak? It also appears that there is plywood built into the bottom in the middle of the fibreglass. Is this normal?
allisondtack is offline   Reply With Quote
Old 08-15-2019, 05:37 AM   #2
Yes, there is plywood in the middle of the floor, and once it rots, you have a BIG problem. So keeping your trailer dry is critical. Read up all the threads on the windows and belly band. Both are extremely common leak sources, pretty much both will leak unless repaired.
You will also find exposed plywood under the kitchen cabinets and under the gaucho too, if you have a front gaucho. Rot in those areas is worse.
Two layers of fiberglass would not support the weight of someone standing on the floor. Many assume the floor is fiberglass. It's not. The floor gets its strength from the plywood. Most fiberglass trailers use plywood or OSB for this. Some have the wood sandwiched between layers of fiberglass, some don't. Being sandwiched protects it more, but makes it a lot harder to repair/replace. People also think molded FG trailers are indestructible. They are not. They just are a lot better than their stick built cousins.
Trilliums are great, but have some well known flaws. Left unfixed, they can ruin the trailer.
Go to the manufacturers section top of the page on the right, and read up on belly band repair and window repair. Both have been covered in depth many times. Lots of good info out there. There are more issues too, like body to frame bolts, and the door hinge attachment.
I rejected the first two 4500s I looked at, one had standing water in the dinette benches (it was raining), the other the wood in the dinette bench was totally dry rotted. Both had soft spots in main floor (rotten plywood). Both trailers were quickly sold to others who I guess didn't look very close. I'm waiting for those two buyers to appear here: "How do I fix this?" I haven't seen either yet.
Water inside a dinette bench is something to be addressed quickly. Don't wait, get it dry, consider some small (1/4 inch or less) holes in the pontoons. Hopefully the plywood is still OK.
Old 08-15-2019, 06:31 AM   #3
John in Michigan's Avatar
As Bill said, the water is likely coming from behind the window frames, the belly band or both. You can view water trickling inside on a dry day by observing inside surfaces while someone sprays with a garden hose outside.
On our Trillium 4500, we found water leaking in behind the window frames, the belly band, as well as the fresh water fill. The city water connection and grey water connection were also leaking during use. Also test the roof vent, door/door frame, and power cable port. Yes they all leaked.
After forty years, the sealant around all fixtures attached to the shell fail. Best way to re-seal windows and other fittings is by removing, cleaning and re-sealing with butyl tape. The belly band is more complicated as described in other threads dedicated to this topic.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
John in Michigan is online now   Reply With Quote
Old 08-19-2019, 09:13 AM   #4
Thank you!
leaks
leaks lead to stinks Drew Bogner Problem Solving | Owners Helping Owners 7 02-24-2007 04:02 PM
*sobbing* It's raining.. it revealed leaks Deb in MN Problem Solving | Owners Helping Owners 6 05-01-2006 02:02 PM
quick fix for leaks Taylor Kissinger Care and Feeding of Molded Fiberglass Trailers 2 12-29-2005 12:30 AM
Gas Leaks Legacy Posts Problem Solving | Owners Helping Owners 2 07-26-2003 10:45 PM
Bathroom Plumbing Leaks Legacy Posts Plumbing | Systems and Fixtures 4 06-20-2003 09:56 PM
