LED tail lights - Fiberglass RV
Old 03-11-2006, 07:10 PM   #1
Trailer: Scamp 13 ft
I'm looking to replace the tail lights on my Scamp with some 7 inch LED ones, but I'm not sure which ones to go with. I have seen ones on the net that say they have 60 diodes and others that say they have 17 LEDs. Are there any brands that you guys would recommend?
Thanks,
Tarek
tarek is offline   Reply With Quote
Old 03-11-2006, 07:46 PM   #2
Brian B-P's Avatar
Unfortunately, the count of LEDs (or diodes - LED is just Light-Emitting Diode) doesn't mean much by itself. LEDs come in all sorts of power levels, so 17 bright ones might be brighter than 60 less-bright ones... or not.
The collective wisdom of FiberglassRV regarding LED tail lights so far is likely found mostly in these posts:
LED Tail Light Princess Auto
LED tail lights
Led lighting
Boler Mods.
There is some discussion in these topics of lights other than tail lights, as well.
Old 03-12-2006, 12:20 AM   #3
Kent's Avatar
Trailer: X Casita Owner
Not sure if these will work for your Scamp but I installed them on my 2004 Casita and they work great. I love the fact that they use existing bulb plug so you can switch back to normal bulbs if needed.
LED Tail Light Module
Kent is offline   Reply With Quote
led lights, light, lighting, lights, tail lights
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 10:54 PM
Very Dim Tail Lights Will Wi Problem Solving | Owners Helping Owners 2 07-16-2008 09:23 AM
New Tail Lights - Help! Chris73 Problem Solving | Owners Helping Owners 13 07-12-2006 10:43 AM
LED tail lights AndyW Modifications, Alterations and Updates 1 02-07-2006 06:38 PM
Tail lights Legacy Posts Problem Solving | Owners Helping Owners 32 07-27-2003 09:29 AM
