LED's in my Bigfoot 17 - Fiberglass RV
Old 06-12-2018, 07:57 AM   #1
Trailer: 2004 17ft CB 1500 Bigfoot
Hi FRB travelers, Need some understanding here and could use your help. I changed all the bulbs in the interior of my Bf to LED bulbs ad added two reading lights to the circuit under the storage units. Now when I plug in my 120 AC from Bf to to the GFI on the house, it triggers the breaker in the GFI and shuts off. I get a brief flash in the Bf from the newly installed very small Led reading lights just before the GFI breaker clicks off. Any ideas??? With thanks, trapper
trapper is offline   Reply With Quote
Old 06-12-2018, 08:32 AM   #2
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
Try dis connecting the reading lights and see if it still happens.
Old 06-12-2018, 09:10 AM   #3
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
Good idea Steve. Remove the thing that you changed and see if it fixes the problem. Also consider leaving the new lights wired as they are and removing the bulbs to see if that changes anything. If not, then disconnect the newly wired reading lights and try again. Just my $.02
"Not all those who wander are lost." J.R.R. Tolkien
TheWanderers is offline   Reply With Quote
Old 06-12-2018, 09:11 AM   #4
I would say its reading a ground fault you could try reversing the two wires that make up the new reading lights as the positive/ negative are not matched. What else is on that circuit ? Do you have a ground wire on the new reading lights.
Daniel A. is online now   Reply With Quote
Old 06-14-2018, 05:10 PM   #5
Thanks guys, I have isolated the circuit with the new LED reading lights. Still pops the breaker in my house GFI. My house receptacle circuit is 15 and 20 amps. Could the 30 amp circuit in the Bigfoot pop the GFI house breaker, even with no current draw from Bigfoot? It appeared to have worked fine when plugged into my garage GFI before I moved it to the house. I know enough just enough to be dangerous!! Help........ trapper
Old 06-14-2018, 05:55 PM   #6
John in Santa Cruz's Avatar
Trailer: 2014 Escape 21, 2002 Ford F250 7.3 Diesel 4x4
not sure I understand how 12V DC LED lighting could be affecting a 120VAC ground fault interrupter.
Old 06-15-2018, 06:50 AM   #7
Smile LED in my Bigfoot
Yes John, I agree, that has been my confusion. Now believe that the fault is in the GFI. So will go to a regular 110 receptacle and do think my issues will be solved. Thanks all for your input. Cheers, trapper
Old 06-15-2018, 07:11 AM   #8
Trailer: Escape 19
GFCI outlets can be tripped by long cords laying on the ground. Not common but has happened before. One other thing that can trip them but odds are you do not have is a hot chassis. But it is something to check.You could try another GFCI outlet or better yet if you have a tick tester or can borrow one do what is show in this link.
https://rvtravel.com/how-to-test-for...in-on-your-rv/
Kenton is online now   Reply With Quote
Old 06-18-2018, 07:55 AM   #9
Smile LED
Problem found as you guys suggested. It was the GFI. Plugged into a regular receptacle in the house and all is well. Since the two circuits AC and DC are separate it was not clear how adding two small led's two a three light circuit would pop a GFI. Now I know just a little bit more about my new to me Bigfoot. Thanks trapper
bigfoot
LED Brake Lights for '86 Bigfoot B17 Dave Gray Modifications, Alterations and Updates 26 04-07-2017 09:26 AM
Ikea LED galley light upgrade in Bigfoot trainjunkie Modifications, Alterations and Updates 1 10-31-2014 02:58 PM
LED Tail Lights For Bigfoot & Casita FTTRV Commercial Posts and Products 25 12-20-2012 11:21 PM
LED Tail Lights For Bigfoot & Casita Deb & Chuck Commercial Posts and Products 1 06-17-2012 09:09 AM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
