05-21-2012, 09:43 AM
#21
Originally Posted by steve dunham
Scamp sells the 1/2" rod for stabilizer Cost about $2.00 I just bought a spare rod this spring from Scamp
Could hardly beat that! If shipping's not too high!
05-21-2012, 09:51 AM
#22
Trailer: 2018 13’ Scamp Standard, formerly had a 2005 13’ Scamp standard
New Hampshire
Stabilizers tip also the BAL
I love the BAL! It stores perfectly on the floor in the bathroom, too.
And as for putting out the rear stabilizers, I get the trailer level and then lower the nose by 5 turns of the jack handle, then put down the rear stabilizers and bring the nose back up. It's usually perfect. Do the process in reverse to put them up. Easy Peasey.
05-21-2012, 07:19 PM
#23
I love the BAL wheel leveler! I was camping this past weekend and used it. A fella in a monster Montana 5th wheel (dual axle, three slides) came over and wanted to know about it. Asked if he could use it on his 5th wheel... ahhhh, no.
05-30-2012, 05:12 AM
#24
Massachusetts
Doh!
Originally Posted by floyd
Mild steel is really not the best choice, go buy a piece of drill rod,cut it in half, slip a piece of heater hose tightly over one end of each piece for a grip and you have two new handles which won't bend, for the price of a drill rod.
As for how they work...Look here...
http://www.scamptrailers.com/Portals...osingASpot.swf
I had no idea the rear stabilizers could be jacked. When I was on site, I used my Trailer dolly as a fulcrum and hooked the ball under the rear bumber to lift the Scamp a bit. I was not able to lift it enough, due to the height of the trailer dolly. Off to HD to find a suitable piece of rod.
05-30-2012, 07:04 PM
#25
I never use my stabilizer rod. Fortunately it's short enough to store with out being in the way.
I simply level the trailer side to side and then drop the tongue about a dozen cranks down or so. I head to the back of the trailer and drop the stabilizer jacks down to the ground. If they don't reach I simply put enough 2 x 6's under them so they touch and go back to the tongue and crack it back up.
Viola' simple pie, solid and stable as can be.
Joy A. & Olive
and "Puff", too
Fulltime
2019 Ram Longhorn
05-30-2012, 07:55 PM
#26
The Scamp video shows what I consider the worst possible method of leveling your trailer. There's too much risk of putting frame in a twisted configuration. Also you could put more weight on the stabilizers than they're rated for.
05-30-2012, 08:09 PM
#27
Picking it up with one hand and stacking take-along solid concrete blocks under the bumper with the other could be worse???
05-30-2012, 08:32 PM
#28
Trailer: 1999 casita spirit deluxe 17 foot
I just a cupple of sissor jacks thay work fine and there cheep at the auto wreckers
05-30-2012, 09:07 PM
#29
You gonna make a video demonstrating that??
05-31-2012, 12:47 PM
#30
Trailer: scamp 13
well,,, being cheap by nature. i carry a couple 12" chunks of 1x6, a couple 2x6, and a couple 4x4.
even if the ground is pretty level, it helps to put them down under your levelers if your in sand or its raining and muddy.
if its not very level, you can put a 2x,or a 1x, or a combination of them to get you pretty close on the low side and just pull your wheel up on them befor you disconect.
oh,,,don't forget to use wheelchoks , you don't want it rolling off the blocks at night when you roll over in bed.
05-31-2012, 12:52 PM
#31
Trailer: scamp 13
oh yes,,and a little forthought as you set up....if your clearly needing a couple extra inches on one side,,,and lets face it,,, how many of us don't have that problem? simply crank the tongue down and set one leveler that amount more then the other side. then when you crank up the tongue it should already be pretty close.
05-31-2012, 03:39 PM
#32
This method is recommended if you like straighten a twisted frame. Which if you use it often enough with a straight frame you might need it to straighten it back.
05-31-2012, 05:57 PM
#33
Please don't use the frame to level the trailer. Trailers are leveled side to side at the wheels and front to back at the tongue.
You've been warned.....
05-31-2012, 06:16 PM
#34
And I've got the twisted frame to prove that you should not use the Stabilizers to Level with.
05-31-2012, 06:36 PM
#35
Trailer: '98 BURRO 17WB
Delaware
Getting back to the stabilizer pattern found on the Scamp, near as I can tell it is the same mechanism found on our Burro. The "jacking" of the stabilizer leg was only revealed to me by the video instruction. Once I found the 1/2" mild steel bar which I knew had accompanied our "pre-owned" trailer, I attempted to use it as a lever and found that I needed to grind a slight champfer on the end to get it to enter outer and inner holes in the stabilizer leg. I am nothing if not a double-ender type guy, so I ground it on both ends. Reacting to Brian's observation about frame twisting, I did a couple of "tests" a few minutes ago. My bar is exactly 1' long. I found that I could insert it and jack the stabilizer into tight contact with the driveway. The distance moved looked to be about 3/8 to 1/2". I could also insert the bar in the next higher hole BUT I could not get enuf leverage to jack it a second time. I do not know that this jack handle was provided with the stabilizers but if it was, I would surmise that the short length was chosen to allow taking up the slack but not repeated jacking resulting in the mechanism taking the wgt. of the trailer. I have never tried using the tongue jack to throw the wgt. on the stabilizers except once by mistake (getting the coupler to hitch elevation). I could feel the resistance in the crank and stopped. Now that Floyd has introduced me to the "approved method" I'm going to use it (but not with 3' of drill rod).
jack
05-31-2012, 06:52 PM
#36
Delaware
I went back to see who's rapping whose knuckles with a ruler and right there in the middle of the blind men and the elephant was Joy A.'s post in which she says her chunkametal is short enuf to not be in the way. I have pinned this comment to my evidence board under "anecdotal." Anyone know for sure what length handle was provided with the stabilizer used by Scamp?
jack
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Leveling the Unit
georgia g |
21 |
06-10-2011 07:08 PM |
leveling the frig
Bud Kennedy |
General Chat |
12 |
04-08-2010 09:17 AM |
Floor leveling
Mac B |
13 |
09-19-2009 02:26 AM |
Leveling a trialer
Legacy Posts |
9 |
06-12-2003 10:21 PM |
Leveling your trailer
Legacy Posts |
23 |
11-10-2002 06:17 PM |
