Leveling the Unit - Page 2 - Fiberglass RV
Old 05-25-2011, 10:23 AM   #15
Originally Posted by Donna D. View Post
I have a couple of bullet levels like Bill referenced. At home, I completely leveled my trailer. It's important to my 23 y/o 3-way refer to be level to work at maximum efficiency. Once level, I then installed two horizontal levels. One under the belly band in front and one under the belly band next to the door. When I get to my campsite, I level front to back with the tongue jack, then level side to side with the BAL leveler. Having everything in place, makes leveling a quick job.
Donna,
Do you level front to back first. I think things generally works better leveling side to side first with the BAL leveler. I usually do the side to side thing before unhitching.
If you do the front to back first, using the tongue jack and the rear stabilizers when you then level side to side you'll unload one of the rear stabilizers which in extreme cases could warp the frame.
Old 05-25-2011, 11:55 AM   #16
Trailer: Casita 17 ft Liberty Deluxe
Originally Posted by Doug Mager View Post
Just my 2 pense worth,
Doug, wouldn't that more properly be a tuppence ?
Mike
Mike Price is offline   Reply With Quote
Old 05-25-2011, 01:25 PM   #17
Donna,
I don't use the standard rear stabilizers that Scamp puts on the rear bumper. I use Wayne's stabilizers and they're deployed after the trailer is level.
Old 05-25-2011, 02:44 PM   #18
Thanks for clarifying. Using the standard rear stabilizers it's a good idea to level side to side first.
Old 05-25-2011, 08:17 PM   #19
Laurie's Avatar
Trailer: 79 Trillium 4500
Thanks for all the info. This is exactly what I needed and will buy a bullet level and install as suggested by Miss Donna. Cheers! LG
Laurie is offline   Reply With Quote
Old 06-07-2011, 10:50 AM   #20
Laurie's Avatar
Just a quick update: the bubble level recommended earlier in this thread is available as an app in the iPhone store. Works like a charm...
Old 06-10-2011, 12:45 PM   #21
Trailer: 1977 Boler
Neat idea! Just reading the forums on my lunch break and installed one from the Android Marketplace - it will even beep when it's level, making it a one person job!
Mark V. is offline   Reply With Quote
Old 06-10-2011, 07:08 PM   #22
cpaharley2008's Avatar
I have a related question if "level" is not a function of the exterior...
Bear with me, this is how my brain works:
I like my stove to be relatively level so I can cook and boil without issues. The fridge floor seems to be "pretty close to" parallel to the sink surface and stovetop surface.
So, if I need to replace the bubble levels on the exterior, can I just set a measuring bowl of water on the stove (and futz around with the trailer) until the water appears level all around the measuring bowl, then install the bubbles?
Is there an easier way?
You are correct in thinking that your stove and sink can be level while the rest of the trailer can be unlevel. The bubble levels on the outside are not that accurate and probably can be moved a little. I'd just use a small carpenter level or bubble level and leave it on your refer/stove. Once it is level then you are good to go, regardless of the exterior bubble levels readings.
leveling the frig Bud Kennedy General Chat 12 04-08-2010 09:17 AM
Floor leveling Mac B Problem Solving | Owners Helping Owners 13 09-19-2009 02:26 AM
Leveling and stabilizing Dave M Towing, Hitching, Axles and Running Gear 20 06-25-2006 08:56 PM
Leveling a trialer Legacy Posts Problem Solving | Owners Helping Owners 9 06-12-2003 10:21 PM
Leveling your trailer Legacy Posts Care and Feeding of Molded Fiberglass Trailers 23 11-10-2002 05:17 PM
