Leveling the Unit - Fiberglass RV
Old 12-10-2008, 08:13 PM   #1
Trailer: 1973 Trillium
Send a message via AIM to georgia g
Same Trillium, new problem. Husband spent the day trying to level the left side up about 1 1/2. Since we have stripped out the stove, frig, and sink should he wait until that has been reinstalled to level or do it first. I wouldn't let it bother me so much but he is a stickler for level and square and I don't think this will ever be level and square. This could drive you crazy if you let it. georgia
georgia g is offline   Reply With Quote
Old 12-10-2008, 08:29 PM   #2
Alf S.'s Avatar
Hi: Georgia... There is no square or level in "Fiberglass"!!! At best is close to or near enough...and boy did it bother the "H" out of me. I suffer from O.C.D. and it's not easy to deal with. Have fun and do lots of camping!!!
Old 12-10-2008, 08:47 PM   #3
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Talking
LEVEL?????? What's that? The only thing I worry about when setting up (after figuring there was no such thing as level or plumb in the Scamp or the Compact) is getting the stove top level so the Wench doesn't complain..... Larry
Larry&Carrie is offline   Reply With Quote
Old 12-10-2008, 09:02 PM   #4
Raya's Avatar
Are you talking about leveling the body shell on the frame? (I wonder because you talked about "doing it now, while the kitchen is out.")
Or are you talking about leveling the whole trailer relative to the ground, like you would do to make your bed level as you were setting up in a site?
Raya
Old 12-10-2008, 10:24 PM   #5
Booker B.'s Avatar
Well, I know in our Trillium that level means the fridge works.
Our Trillium's stove/fridge area is not level with the floor - so I can either level the trailer for a flat floor or level the trailer for a working fridge. Guess it all depends what temperature you like your beer =)
Edit: I use a BAL leveler to level our trailer. With that on one wheel and the tongue jack we can level accurately within a few minutes.
Old 12-10-2008, 10:35 PM   #6
james kent's Avatar
Trailer: Boler 1984
I always carried a piece of 2x6, to put under one wheel when parked, to level the trailer. When they made ours they got the body higher on one side than the other.
Old 12-10-2008, 10:39 PM   #7
Trailer: Fiber Stream
Unhappy
Same Trillium, new problem. Husband spent the day trying to level the left side up about 1 1/2. Since we have stripped out the stove, frig, and sink [b]should he wait until that has been reinstalled to level or do it first.
The ONLY reason to be a stickler for level, as Booker B. stated, is for the gas/electric powered, absorption type refrigerator to run properly. The OLDER the fridge, the more critical it is to level it.
Ice Boxes do not need to be critically leveled. Neither do electric only powered compressor type refrigerators.
Unless he is installing those bubble level fixtures to the front and side right now, He should wait until the kitchen and the fridge are re-installed.
I wasted a lot of time and effort leveling up my old Compact Jr. which did not have an absorption type fridge.
Old 12-10-2008, 11:20 PM   #8
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Just my 2 pense worth, but I believe that in rebuild stage I'd take the time to get the frame as level as I could (for work purposses) and add the goodies inside getting them as level as posssible.
In hot-rod building this is the accepted proceedure from the start. <Start level, end level> While you are at this stage, take the time to do as good a job as you can.
This will also make your camping set up a lot easier.
Old 12-11-2008, 07:45 AM   #9
Thank you, thank you. I just made my husband read all your comments. It is the body/shell that he is trying to level. Loosened the bolts on the left side (they were rusted of course) and he is putting wooden shims in and is trying different thicknesses. Maybe today this will be over. Thanks all. georgia
Old 12-11-2008, 07:51 AM   #10
And of course, he's starting with a perfectly level frame. Right?
Old 12-11-2008, 02:08 PM   #11
Yea!! The body is level and now we start on the inside. I am giving up the drawer to have a little larger frig. Silverware can go overhead. We shall see. Still in the planning stage. Thanks all. Georgia
Old 05-24-2011, 10:39 PM   #12
Laurie's Avatar
Trailer: 79 Trillium 4500
I have a related question if "level" is not a function of the exterior...
Bear with me, this is how my brain works:
I like my stove to be relatively level so I can cook and boil without issues. The fridge floor seems to be "pretty close to" parallel to the sink surface and stovetop surface.
So, if I need to replace the bubble levels on the exterior, can I just set a measuring bowl of water on the stove (and futz around with the trailer) until the water appears level all around the measuring bowl, then install the bubbles?
Is there an easier way?
Laurie is offline   Reply With Quote
Old 05-25-2011, 05:48 AM   #13
Trailer: 2009 Scamp 16 ft / 2014 Ford E-250 cargo van
Just get one of these and set in fridge.
Bill K
Old 05-25-2011, 07:47 AM   #14
I have a couple of bullet levels like Bill referenced. At home, I completely leveled my trailer. It's important to my 23 y/o 3-way refer to be level to work at maximum efficiency. Once level, I then installed two horizontal levels. One under the belly band in front and one under the belly band next to the door. When I get to my campsite, I level front to back with the tongue jack, then level side to side with the BAL leveler. Having everything in place, makes leveling a quick job.
leveling the frig Bud Kennedy General Chat 12 04-08-2010 09:17 AM
Floor leveling Mac B Problem Solving | Owners Helping Owners 13 09-19-2009 02:26 AM
Leveling and stabilizing Dave M Towing, Hitching, Axles and Running Gear 20 06-25-2006 08:56 PM
Leveling a trialer Legacy Posts Problem Solving | Owners Helping Owners 9 06-12-2003 10:21 PM
Leveling your trailer Legacy Posts Care and Feeding of Molded Fiberglass Trailers 23 11-10-2002 06:17 PM
