Lifting the axel - on one side? - Fiberglass RV
Old 04-10-2011, 01:30 PM   #1
Trailer: 1971 Amerigo
So I'm under the Boler working on the frame rust when I notice that the axle has been raised about 2" by means of heavy washers and long bolts.
On one side.
No - really - only the offside has been raised..the near side is at stock height. I can't for the life of me figure out why somebody would do that...can you?
Peter_Crowl is offline   Reply With Quote
Old 04-10-2011, 02:58 PM   #2
Find a perfectly level spot and Use a LEVEL to make sure it is level then park the egg on it.
Now go inside the egg and use the level to see what is going on.
If it level then he did that to correct something and if it leans to the non washered side, who knows.
Old 04-10-2011, 03:03 PM   #3
Good idea.
There's no evidence of a frame issue but that would confirm things.
Old 04-10-2011, 07:11 PM   #4
Trailer: 1980 Burro
On one side.
My guess is that the rubber suspension inside the axle may have sagged on one side and instead of replacing the axle they used washers to make the trailer sit level. You could check the angle of the arms that support the hubs to see if one side is at a different angle to the frame than the other side.
Andy B is offline   Reply With Quote
Old 04-10-2011, 07:12 PM   #5
Joe Z's Avatar
New River AZ
Maybe the rubber torsion bushings on that side of the axle are bad?? you can measure the up angle degrees on both sides to get that answer. Axle should be on the ground with weight on it when doing the calculation...... In the pictures The side with the washers does look like the rod is sitting higher in relation to the lower bracket
Joe
Sorry Andy...... We're both typing at the same time but it seems we're both saying the same thing. LOL
Old 04-10-2011, 07:34 PM   #6
Great minds thinking alike as usual :~)
It'll be a few days before I can measure it laden - but unladen on the lift they're equal.
I like it as a reason though.
The only other thing I can think of is that with the bit of an angle to it it's shed water off the roof to one side when parked - but why have it shed toward the door
Old 04-10-2011, 07:39 PM   #7
Joe Z's Avatar
New River AZ
If that's an original axle it's at least 31 years old..... look and see if there's any old scrape marks inside the wheel well on that side....maybe it was rubbing up top in there when he hit bad dips in the road (mushy on that side)??? You gotta let us know what you find.
Joe
Old 04-10-2011, 08:13 PM   #8
Joe
I will - I'm big on contributing to the knowledge base whenever I can
Old 04-11-2011, 10:05 AM   #9
james kent's Avatar
Trailer: Boler 1984
Our Boler leaned to the off side badly and needed a new axle. When installing the new one it was found out that the floorpan in the Boler had been installed offset to one side and I now have spacers similar to yours to level the trailer.
Old 04-11-2011, 05:57 PM   #10
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Peter Crowl... One thing Bolers aren't is "Rocket Science". Usually the appliance side, fridge, stove, sink and furnace(if equip'd), is a little lower than the closet side. That said I'd put my $$$'s on the axle being shot.
You can check Dexters web site and look up a #9 2200lb. Torsion axle spec's. That's the one that most people use now. They will make them to the exact tube length that you require. Once replaced the trailer will sit higher and ride better. One fly in the oinkment could be changing from a leading arm to a trailing arm axle and making sure it's centered in the wheel opening!!!
The Scout model used a 1250lb. and the Voyageur and Deluxe models used a 1650lb axle as std equip...at least the Earlton Ontario factory did in '77.
Old 04-11-2011, 06:15 PM   #11
Joe Z's Avatar
New River AZ
Why are they changing from a leading arm to a trailing arm?_______
Joe
Old 04-11-2011, 06:41 PM   #12
Alf S.'s Avatar
Hi: Joe Z...That's one question you'd have to ask Dexter about!!! I've yet to replace my project trailers axle...but I have to! The frame requires some repair and I might get a new one of those while I'm at it too!!!
Here's a pic of the 3500# Dexter axle under our Escape 5.0
Old 04-11-2011, 09:13 PM   #13
Hi Alf,
My axle is trailing.
I just bought a 3,500# Dexter for the Amerigo so I've been through the measurement process. I also took my old axle to Redneck so they could confirm my numbers :~)
I need to do some more looking and checking but I'm beginning to agree that the axle needs to be replaced.
P.
Old 04-11-2011, 11:03 PM   #14
Roy in TO's Avatar
Peter,
It looks to me that at one time your axle has been repositioned from a leading arm configuration to trailing arm. If they didn't calculate right the camber bend in the square part of the axle would hit the floor frame. Maybe the extra washers compensated for that and "lean" in the trailer.
Lifting the Scamp 13' Earl E. November Modifications, Alterations and Updates 23 10-14-2014 05:14 PM
Compact Axel Don'n'Deb Care and Feeding of Molded Fiberglass Trailers 0 07-26-2010 04:07 PM
Adding leafspring suspension to, or lifting a Scamp ReilleyS Problem Solving | Owners Helping Owners 15 12-20-2009 07:51 PM
Body lifting a boler Derek K Modifications, Alterations and Updates 20 05-30-2007 03:07 PM
Lifting Scamp and Bolers? Legacy Posts Towing, Hitching, Axles and Running Gear 5 01-30-2003 07:10 AM
