Light - Fiberglass RV
Old 06-29-2012, 10:50 PM   #1
Trailer: 99 Scamp 16
Idaho
Light
The light in my scamp 16' by the rear bed won't turn on, all the other lights work fine and I've replaced the bulb still nothing. Any ideas on a easy fix? Thanks!
John
camper1887 is offline   Reply With Quote
Old 06-29-2012, 10:58 PM   #2
Is it a 12 volt light under one of the overhead bins? if so check the wire connections inside the overhead bin.
Old 06-29-2012, 11:02 PM   #3
Idaho
It is on the back side of the fiberglass panel for the side dinette facing towards the bed in the rear.
Old 06-30-2012, 07:53 AM   #4
Trailer: Casita 17 ft DLX SD
Light repair
I just fixed the wiring to the same Light in my 1999 Scamp 16 ft. The wires from the fixture splice to the 12 volt feed wires under the side dinette bench seat . I removed the drawer in the bench seat and was able to get at the splice which was bad . It is a long reach through the drawer opening to the splice . so with the help of my wife I fed the wires (splices) into the storage area under the bed where they are more accessible , repaired same and returned the splices to the area under the bench seat where they are safe and out of the way. Hope this helps but ,I am not sure if all Scamps are wired identically at the factory.
steve dunham is online now   Reply With Quote
Old 06-30-2012, 09:22 AM   #5
Idaho
Thanks for the info I will give that a shot and see what I can find.
John
Old 06-30-2012, 09:33 AM   #6
On my light up in that location there is actually a piece of fiberglass stuck inside the cabinet at the end that covers all the wires to that light as well as on my trailer the 12V plug and Cable TV connections. Its a false wall - its not attached just pushed in tight. Its possible you have a loose connection behind it as well. You could also put a voltage meter onto the light socket to see if you are getting any power if you are then it may just be the bulb socket needs some adjustment in order to get a better contact with the bulb.
light
Installed Smart Light 1000 Motion Activated LED porch light Fran L Modifications, Alterations and Updates 2 02-01-2012 02:05 PM
Gas Light? danny m Problem Solving | Owners Helping Owners 9 05-29-2008 03:36 AM
Pilot light won't light (Casita) SW6P Legacy Posts Problem Solving | Owners Helping Owners 5 08-06-2003 09:12 PM
Porch Light Legacy Posts Problem Solving | Owners Helping Owners 8 06-10-2003 10:21 AM
Let there be light General Chat 0 12-31-1969 07:00 PM
