Lighting Oven - Fiberglass RV
Old 03-14-2012, 09:09 AM   #1
Lakeville, CT
Lighting Oven
I've had my '86 Scamp for a year but have not tried the oven until now. It looks almost unused inside. The pilot lights fine and according to directions but the oven burner does not light. When I put a lighter directly on the temperature sensor it lights immediately. Looking at the pilot/burner/sensor assembly it seems almost like the sensor is in the wrong place to catch the heat of the pilot. If I took it off and flipped it over I think I could make it work but I thought I'd ask for advice first because of the, you know, fire aspect. I'll attach a picture below. Can any confirm that theirs is assembled this way?
It's a trav'ler, can't see the model number.
Thanks in advance.
biw314 is offline   Reply With Quote
Old 03-14-2012, 09:19 AM   #2
Gina D.'s Avatar
West Coast USA
my advice is to ask a pro in propane appliance repair. Its far too dangerous to guess.
Sorry, I know thats NOT what you want to hear, but this is a very serious safety concern.
Ask me what its like to be inside a trailer when a propane leak blows. Its not very fun.
Old 03-14-2012, 09:30 AM   #3
Lakeville, CT
Here it is with the pilot lit and in heating mode.. The flame seems ample but is certainly not enveloping the sensor.
Old 03-14-2012, 12:07 PM   #4
Tim Wood's Avatar
Trailer: Class B for now
NY
I think what you are referring to as the sensor is the Thermocouple . And if that is the case it should be directed into the flame of the pilot light to work. As the pilot heats up the Thermocouple it sends current to the gas value to open. But I'm just guessing here, so take with a grain of salt. Maybe someone else will chime in.
Old 03-14-2012, 12:44 PM   #5
DonDeutsch's Avatar
I would move the sensor.
DonDeutsch is offline   Reply With Quote
Old 03-14-2012, 01:48 PM   #6
Trailer: scamp 13
if you apply heat to the thermocoupler, say with one of those long butane bbq lighters, does it fire up?
if not you simply have a bad thermocoupler and they cost just a few dollars to replace.
i'd probably buy one and replace it anyway.
it actually looks like your pilot is too high. its putting out all the heat above the thermocoupler.
Old 03-14-2012, 04:54 PM   #7
Trailer: gave up!!
OMG!! I would have need some fresh undies after that...
Glad you are ok though!
John_M is offline   Reply With Quote
Old 03-14-2012, 05:01 PM   #8
And by the way, turning the gas on and putting your head in the oven is not a recommended procedure
Old 03-14-2012, 07:00 PM   #9
Trailer: 1989 Bigfoot
Hi William, the pilot lights but does the secondary pilot come on I can not see in the picture. If the secondry pilot is lighting it can sometimes take a minute to heat the senser to open the main valve. If the secondry pilot is not lighting I would look at the valve on oven on the face of the stove, if the secondry pilot is lighting could be the safety that is behind the burner in the oven
Hope this helps
ken h is offline   Reply With Quote
Old 03-14-2012, 08:38 PM   #10
I had a closer look at the flame it looks like it has a white tip on it. Does the secondry flame make a small roaring sound ? In the picture the flame looks lazy. It is probably just needs the orfice cleaned
Ken
Old 03-14-2012, 08:47 PM   #11
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
The thermocouple needs to be pushed up through the opening. It is to far back. The flame needs to surround the couple, which in turn will send the electric current to the valve. A chemical reaction produced by the metals in the thermocouple produce's an electric current which opens the gas valve.
The picture shows it behind the flame.
Old 03-14-2012, 09:29 PM   #12
Actually in the older ovens it is a mercury bulb, they were outlawed around 2000 now they have a thermocoupler
Old 03-14-2012, 09:51 PM   #13
Mercury bulb in an oven?
I thought that thermocouples (it is s not r) were used for ages. Mercury bulb in an oven, sound as a poisonous bomb. I know mercury switches sensing level or acceleration but not in an oven? What would the mercury do? sensing temperature? Maybe I am missing something. But, I am more than willing to learn, that is what life is all about, especially on retirement.
George.
Old 03-14-2012, 10:17 PM   #14
Hey George, it is not a bomb . The mercury expands when heated. For example when you heat a thermometer the mercury in the tube rises. In a closed tube with a mercury bulb at the end when its heated it causes pressure which in turn pushes the gas valve open to release gas to the main burner. It is environmentally dangerous that is why it has been changed to a thermocoupler.
Toaster oven/Microwave/Convection oven Karalyn General Chat 22 02-04-2017 10:45 PM
L.E.D. Lighting Glen Aldridge Classified Archives 4 03-26-2011 05:32 PM
lighting christineb Problem Solving | Owners Helping Owners 5 07-26-2010 04:41 PM
Interior Lighting John Jesse Electrical | Charging, Systems, Solar and Generators 18 05-15-2010 03:08 PM
Toaster oven/Microwave/Convection oven Camp Cooking, Food & Recipes 0 12-31-1969 07:00 PM
