Lighting the stove? - Fiberglass RV
Old 09-05-2007, 08:58 AM   #1
The cook surface in my trailer requires a match or lighter to light it. My Fold_N-Go Colman campstove requires the push of a button to activate the piezoelectric lighter, my gas Bar-B-Grill uses a piezoelectric lighter. I did a limited web search for a piezoelectric lighter retro-fit for my Suburban cook top. I didn't find any. I imagine I could add the same lighter that's used in bar-b-q grills. Anybody know anything, like why this shouldn't be done? Is there a made for Suburban lighter?
Thanks
Old 09-05-2007, 09:05 AM   #2
Chester Taje's Avatar
Thanks
No but it sounds like a good idea.
Old 09-05-2007, 11:32 AM   #3
Brian B-P's Avatar
I have the same issue. Gas stoves are certainly available with various sparking devices to light them. The best setup, in my opinion, would be a battery-powered igniter which sparks until the flame starts; this is a safety feature, since it would ensure the fastest light (less time running propane into the interior) and could re-light a burner which goes out. It's neither rocket science, nor foreign to RVs: that's what Direct Spark Ignition furnaces and water heaters have.
I use a barbecue lighter, but find the whole process annoying: you push a couple of balky safety releases, then pull a trigger to make a piezo-driven spark to light the butane which might be coming out and might start burning, to then use the butane flame to light the propane. That spark could do it directly, and skip the whole butane part. By the way, butane is "heavier" than propane, and thus refuses to effectively vapourize at the temperatures when you really want to light the stove and furnace.
I found an insanely overpriced barbecue lighter which has a battery and auto-ignites, but it still fires up the unnecessary butane.
I tried an add-on piezo igniter for a campstove (from Mountain Equipment Co-Op), but aside from needing a handle (it is intended to be permanently mounted in a specific single-burner stove), it's spark isn't quite "hot" enough to reliably light the Boler's stove.
My plan was to find a battery-powered lighter intended for installation in a barbecue, and modify it with a handle for hand-held use.
In the meantime, I continue to curse at butane lighters.
Old 09-05-2007, 11:39 AM   #4
Dennis U's Avatar
Trailer: 1999 19 ft Scamp 19 ft 5th Wheel / 2003 Toyota Tacoma
I also use a barbecue lighter with a piezo spark. Long ago mine ran out of butaine, but the ignitor still functions, and lights my water heater and stove.
Dennis U is offline   Reply With Quote
Old 09-05-2007, 12:30 PM   #5
I think Morgan has the best solution however should U want to invest lots of time and effort, you can purchase a piezo device where they sell BBQ grill parts and retrofit.
Or: Where they sell camp stoves they also have a device similar to what Morgan showed that has a flint in the end of it and when you squeeze the handle it rotates the wheel and sparks fly.
Note: Morgan's lighter has a piezo spark in the end of it and will more than likely ignite the stove.
Old 09-05-2007, 12:36 PM   #6
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I may try liberating one from the stockroom at work. I'm not sure I'd like using that to start a stove, though, I've always preferred a real match.
Bobbie
Old 09-05-2007, 02:47 PM   #7
pjanits's Avatar
Trailer: 17 ft 1986 Burro
I wonder how a Propane torch lighter would work?
I usually just use book matches when I can't find the stupid barbecue lighter.
Old 09-05-2007, 04:15 PM   #8
Brian B-P's Avatar
Not very well, in my testing.
I assume we're talking about the ones with a wire handle which you squeeze to drag a flint across a rough surface, inside a "cap".
Since the flint is inside a large cap, it can't be placed right in with the burner (unless you remove the grill), so it isn't very close and I found it didn't work well.
Those flint-on-the-end things like Morgan showed seem promising... I had not seen them, but now I know what to look for.
I would still prefer a repeating series of electric sparks...
Old 09-05-2007, 08:27 PM   #9
Dave Mac's Avatar
Trailer: Burro 13 ft 1979
I'd start with one of these either new or off an old Bar-b-Que.
http://www.bar-b-que.com/store/item.asp?IT...EPARTMENT_ID=59
Dave Mac is offline   Reply With Quote
Old 09-06-2007, 10:11 AM   #10
Brian B-P's Avatar
A more direct answer to this question:
A single-burner campstove obviously need only one igniter, and a BBQ is normally lit from one point (thus one igniter) even if it has multiple burners (each one lights from the next). As implied in my previous post (and Herb's) a built-in lighter would presumably need one sparking device for each burner: maybe that's four piezo igniters, or one with the output to spark at four places, but it's a design challenge either way.
I don't know of any reason why it shouldn't be done, only why it might be difficult or expensive.
Old 09-09-2007, 10:06 AM   #11
Bob H's Avatar
Trailer: 1983 Scamp 13 ft Standard
A inexpensive solution may be to attach one of these near the burner of your stove...
Used to light gas lanterns, I'm sure it can be fitted near a stove burner. Needs no batterys and provides a flint spark.
Here's a link...Coleman Spark Igniter
Good Luck,
ConwayBob
Check out my Scamp restoration video on Youtube, & my Ham Radio Blog. Or take the 50 cent tour...
Bob H is offline   Reply With Quote
Old 09-09-2007, 07:27 PM   #12
Patrick M.'s Avatar
Trailer: 2007 Casita Liberty (Sold 2011)/ Honda Odyssey
If you want electric starting, I found this $20 gadget, and it or something similar could be taken apart and adapted as an in-stove starter, me thinks. BBQ makers probably have add-on electric ones but I haven't found them if they're out there.
http://www.cabelas.com/cabelas/en/template...equestid=100210
Patrick M. is offline   Reply With Quote
Old 09-10-2007, 12:10 PM   #13
Our BBQ has 5 burners and an electric spark device that has a couple of AA batteries inside and when U press the button, it sparks on all 5 burners at the same time so there R devices out there that U could adapt to the cook top, You just have to look for them.. I will look to see if there is a name on the device and post it here If I can find one.
Old 09-10-2007, 06:45 PM   #14
Brian B-P's Avatar
If you want electric starting, I found this $20 gadget...
That's exactly what I have been looking for, for my stove, furnace, water heater, and BBQ. Thanks!
I received a Cabela's catalog last week, and immediately went through it looking for new and interesting stuff like this, and still had not seen one.
This is a Camco product, and their web page for the GM12 Continuous Ignition Multi-Sparker loads to sellers (Camco does not sell directly), which may be useful for someone without a local Cabela's (there are none here), or not wanting to order from them. Now I have an Alberta supplier list! (They're a welding supply store...)
I would be happy with it even in it's normal hand-held form, but I realize Bryon is looking for a built-in. If anyone adapts this to built-in, please share the method and results with us.
L.E.D. Lighting Glen Aldridge Classified Archives 4 03-26-2011 05:32 PM
lighting christineb Problem Solving | Owners Helping Owners 5 07-26-2010 04:41 PM
Lighting the fridge? Val L Problem Solving | Owners Helping Owners 2 05-21-2009 10:48 AM
Led lighting JIMZ Problem Solving | Owners Helping Owners 48 01-19-2006 06:31 PM
LED lighting Legacy Posts Modifications, Alterations and Updates 50 07-22-2003 10:25 PM
