Lighting type and locations for a Scamp - Fiberglass RV
Old 10-14-2014, 10:51 PM   #1
Trailer: Scamp - The Haunted Mansion
Can anyone tell me what types of lights are standard in a Scamp and what their locations are? Since we are starting from scratch, we have the option to do anything, but I would like something to go on...
Thanks!
Sent from my SCH-I535 using Fiberglass RV mobile app
Sohkraites is offline   Reply With Quote
Old 10-15-2014, 12:41 AM   #2
If you go to Scamps webpage and under showroom it will show you pictures of each trailer and the lights that are in them.
Normally there is an outside light. If you have a bathroom there is also a light above the toilet, a light on each of the rear overhead bins, as well as one over each side of the kitchen area. Mine also had one on the end of the upper cabinets which I never used and one that was centred over the rear table that I took out when i installed the fantastic fan. The older trailers such as mine also had a 110 florescent light on the back wall on the drivers side of the kitchen but Scamp doesnt put those in anymore - instead they have put a double light up under the cabinets - which they did not do in the past. On my 16' there is also a light up on the front outside bathroom wall for use in the bunk area.
Scamps on-line parts store has all the lights they use..... highly recommend you go with LED lighting though as a lot of people here have changed out their stock lights to LED.
Old 10-15-2014, 06:30 AM   #3
Thanks!
Do the under cabinet LED lights provide enough light inside the camper? I remember my folks had a pickup/camper and it had one overhead flourescent light to provide overall lighting, and both 110v and 12v lights in various places (like on the upper bunk) for reading, etc.
Old 10-15-2014, 07:19 AM   #4
Timber Wolf's Avatar
North Florida
I have replaced the front bunk light and rear driver's side dinette light on my Scamp with these: Amazon.com: Gold Stars GW21500 RV Reading Light MR16 Base LED Bulb 12v Satin Chrome: Automotive And we like them a lot better than the stock flat light. I have one more that I am adding to the passenger's side dinette (rear of upper cabinet) also. If I had to do it over I could have bought a three pack of them off ebay cheaper. I am changing the kitchen flat light to this: Amazon.com: Gold Stars F3528001 LED Dome Light Fixture Single 921 Wedge 150 Lumens 12v Natural White (1): Automotive but have not done so yet so can't say much about it. At some point I expect to change the 120V florescent to some 12V LED also.
Old 10-15-2014, 07:44 AM   #5
Scamp lighting is minimalistic. In my 13' standard, it consists of an outside 12V porch light, two interior 12V lights, one on either end of the upper kitchen cabinet, and the now-discontinued 110V fluorescent above the sink, which we have never used because we never camp with hook-ups. The lights Carol mentioned on the rear storage bins (also available in the front) are optional 12V reading lights. Scamp will also put a second porch light over the front tongue area if you want.
Two places I would add 12V lights if I were starting from scratch are at the top of the closet to better light the center of the trailer, and underneath the kitchen cabinets, to light the workspace. I wouldn't bother with any 110V lights.
I would definitely go LED for the lower power draw, but beware of cheapies. I've read some discussions about low output and unpleasant color tones. I haven't made the switch, so others will have to guide you to the best ones to use.
Old 10-15-2014, 08:24 AM   #6
fusedlight's Avatar
Trailer: 16' 1998 Scamp
Our '98 Scamp was VERY dim. I put dual 12" LED strips under the dinette cabinet (they can be turned on as 1,2,1 and 2), and strips under the back cabinets and a shelf I stretched across the back. All 12V incandescents have been replaced with LED's. SHINY!
fusedlight is offline   Reply With Quote
Old 10-15-2014, 08:51 AM   #7
Originally Posted by Sohkraites View Post
Thanks!
I also would not bother with any 110 lights and just go with all 12v as Scamp now does as it makes more sense. I do not know which layout you have but I would also as Scamp has done put a double light on the side of the kitchen where the stove and Fridge are if you have that set up and have found that a single works fine for me under the cabinet on the sink side.
I also agree that a light up on the tall cupboard by the door would be a good idea as well.
As far as LED's go - yes plenty of light for reading assuming you do your homework and purchase ones with a high enough lumens rating. I know a few folks have been unhappy with their chosen LED's but suspect in many of those cases the lumens was not high enough - I like ones that are 300 or more. Also watch the colour - warm white or cool light (which will give a bit of a blue light).
Lots of threads regarding LED's here - use the search function at the top and choose the bottom search box (google) on the drop down box for the best results.
Old 10-16-2014, 03:54 AM   #8
TomK's Avatar
We have a 2014 Scamp 13 Standard with couch / bunk beds. We ordered the city water option package, and it came with 3 interior lights standard as well as a "porch" light. The 3 pancake style lights are mounted over the sink and one on each side of the overhead kitchen cabinet.
We added 2 swiveling reading lights. One is below the upper front cabinet, next to the entry door. It is very handy when entering the dark trailer at night. You can turn it on before entry to keep from fumbling around to find a light fixture. The other reading light is under the rear driver's side upper cabinet. Fine for reading in bed. We also ordered a pancake style light mounted on the ceiling just above the rear window. This would be handy for eating at the dinette table, games, etc. Another light we opted for was the "porch" light on the front of the trailer. This has proven very helpful when hitching up in the dark, or spotting your trailer when returning to it at night.
Shortly after we picked up our Scamp, I replaced all the interior and both porch lights with LED's. They are brighter, last forever, and use a fraction of the current an incandescent bulb uses. Here is the thread that explains that:
Replaced Lamps with LED's
Hope this helps.
Tom
Old 10-16-2014, 04:02 AM   #9
TomK's Avatar
Gary, I'm interested in LED strip lights for our Scamp. Do you have a source for your's? Are you satisfied with them? I only need a 2 foot run, so I may need to shorten the string. Brightness is important, but I would also like to dim them when needed. I like your 1,2, 1and 2 solution. Thanks!
Tom
Old 10-16-2014, 06:18 AM   #10
Thanks, Tom! I had looked at the showroom on the Scamp site, but it really didn't show all the lights. Definitely are going to use the LED...like you said in your post, they are more durable and will last for practically forever.
On the front "porch" light -- is it the same fixture as the one on the side?
Thanks again!
- Tony
Old 10-16-2014, 07:22 AM   #11
TomK's Avatar
Thanks again!
- Tony
Yes they're the same fixture. I bought an amber lens cover for the one next to the entry door at Camping World. It helps keeping the bugs away.
I think your doing the right thing by asking questions Tony. You'll get many opinions here. Figure out what's important to you, and order the trailer to suit your needs. You'll be happier with the final product.
Tom
Old 10-16-2014, 07:59 AM   #12
fusedlight's Avatar
TomK... just look up "LED Light Strips" on eBay and you'll have a ton of options. There are two main ways to go. You can get the pre-made strips in a metal housing. They have leads already attached so all you have to do is add a switch. The other is LED's on a flexible strip. You cut to length, add a connector at the end, and add a switch. Make sure you get "warm white", or else you'll be basking in a harsh blue glow.
Old 10-16-2014, 09:03 AM   #13
TomK's Avatar
eBay. That's a good idea Gary. It would be nice to see the lights before buying to make sure they're bright enough, but maybe I'll get lucky. You're right about looking for warm white lights too. Thanks!
Tom
Old 10-16-2014, 09:26 AM   #14
Carl Pa's Avatar
In our 2014 scamp, the lighting is very good we do not feel like we are in a dinghy dark place, it lights up every thing that needs to be lit up. We were surprised that the other campers in the camp ground kept their campers so dark. Wife went out to the rest room in the dark, i asked, " did ya have any trouble finding the camper" She said, "nah, with all those giant motor homes, ours looks like a light bulb". Carl
Carl Pa is offline   Reply With Quote
light, lighting, scamp
Suggestion: block ice locations sticky Bobbie Mayer Forum Admin, News & Announcements 16 08-07-2012 06:19 AM
camping locations Ian-Vicki General Chat 20 04-29-2012 11:40 PM
running light wiring - do you know the locations? calindor Problem Solving | Owners Helping Owners 3 09-12-2011 12:50 PM
Fun Locations to Visit - Pacific NW Mark G. General Chat 9 11-21-2009 05:17 PM
