Lights go off when pump is turned on (12V) - Fiberglass RV
Old 09-10-2014, 09:07 PM   #1
Trailer: 1990 13 ft Casita DLX #6
Question Lights go off when pump is turned on (12V)
1990 Casita. When running off the battery the lights go off (pump doesn't run) when I turn on the pump. If I turn off the water pump the lights will go back on after a short delay. New fully charged battery.This doesn't happen when plugged in to 120 V power. Both will work on 120V. Any ideas why this is happening?
Losthwy is offline   Reply With Quote
Old 09-10-2014, 09:38 PM   #2
Trailer: Class A Motorhome
Sounds like there is a short that is popping a self resetting circuit breaker. The slight delay afterwards before the lights come back is the circuit breaker cooling and resetting. I suspect that you also hear a small click.
Old 09-10-2014, 10:16 PM   #3
Dan Meyer's Avatar
Is the battery properly connected? Typically the black wire at the battery is NOT negative. I would also check connections at the battery any splices between the battery and converter in both the positive and negative cables.
Good Luck!
-- Dan Meyer
Old 09-12-2014, 07:51 PM   #4
I will check the connections.
Old 09-13-2014, 04:23 AM   #5
Raz
Raz's Avatar
I agree with Bob. I would suspect a short beyond the water pump switch. It could be as simple as worn insulation at a wire staple or a bad pump. Raz
Old 09-13-2014, 06:58 AM   #6
The delay of the lights coming on makes sense it's a delay of a fuse resetting. Where would this fuse be and what does it look like?
Can you test a pump?
Old 09-13-2014, 07:15 AM   #7
It's not fuse, it's a circuit breaker and they are usually small metal cubes with two wire posts on them. Listen near the battery area and you should hear a click when it trips and/or resets.
Old 09-18-2014, 09:40 PM   #8
It was the converter. I removed it and separated the 120 v and 12 v systems. Worked just fine.
Old 09-19-2014, 08:48 AM   #9
fusedlight's Avatar
Trailer: 16' 1998 Scamp
I just LOVE the wiring conventions in the Scamp. AT the battery it's the usual Red=POS and Black=NEG. Once you get IN the Scamp, it's Black=POS. I guess the logic is that it's the "hot", not ground, wire... as with AC. Oh well... it builds character, I suppose.
fusedlight is offline   Reply With Quote
light, lights
Meguires Wax turned parts of my Acorn PINK !!!! NancyS Care and Feeding of Molded Fiberglass Trailers 10 08-17-2013 06:33 AM
Power draw from tv battery when turned off Wallo Towing, Hitching, Axles and Running Gear 39 06-08-2013 11:36 AM
Drop Axle Turned Upside Down? KeesV Problem Solving | Owners Helping Owners 17 04-09-2013 02:31 PM
Lurker turned member Cadet85 Hi, I am.... 9 07-12-2011 07:08 PM
Turned my S into a Scamp! Legacy Posts General Chat 5 07-09-2003 08:24 AM
» Trailer Showcase
"Ollie"
PhilS
Lander
robirob
