Lights in my Scamp pulse - Page 2 - Fiberglass RV
Old 08-01-2016, 07:34 PM   #15
Trailer: Casita 17 ft DLX SD
Originally Posted by gordon2 View Post
He does not even own a $4 multi-meter and you want him to check the output with a $400 oscilloscope?
Might be cheaper to just replace the converter on the gamble that it solves the problem.
If your want to play at being an electrician then you need to dress the part. If the OP doesn't own or know how to use a meter than replacing the converter is probably above his pay grade.
Old 08-01-2016, 08:07 PM   #16
Originally Posted by Scruffy View Post
Yes Carol, that's what I'm thinking and I'm already pricing them.
The PD-4045 Power center is a popular replacement for the original Scamp converters.
Old 08-01-2016, 08:24 PM   #17
Well if your point is that its best to get someone more expert to help out in person, then you might be right.
But a typical converter has a 120 volt AC connection (often just a plug like about everything in your home), and two other connections for the 12 volts DC. Yes, you need to match positive and negative on the DC side.. but that is light years easier than learning to use an oscilloscope.
light, lights, scamp
12 v Battery Maintainer A Pulse Teck Product to consider Carol H Electrical | Charging, Systems, Solar and Generators 17 10-23-2013 09:17 PM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
