Lil Bigfoot ground/axle clearance... 4"? - Fiberglass RV
Old 02-12-2016, 04:06 PM   #1
EllPea in CA's Avatar
Trailer: 1989 Lil Bigfoot
CA
Yesterday when we were under the trailer exploring the brake situation, Ron measured the clearance below the axle... finding it was 4 inches.
I should clarify that the trailer is not sagging around the frame, and there is good clearance between the tire and the wheel well. We also have those roller/casters underneath in the back to protect the body from damage on curbs, etc.
But that 4 inches along the axle seems excessively low. Is this normal, or did someone do a strange alteration? I can post a picture if necessary.
Thanks,
Ellpea
Best,
EllPea in CA
EllPea in CA is offline   Reply With Quote
Old 02-13-2016, 08:06 AM   #2
ZachO's Avatar
Trailer: Sasquatch
Montana
4" from the axle tube to the ground? Is it the same distance all along the axle, or just in one spot?
The clearance will be determined by tire size and whether you've got the "drop" axle. I'll measure the clearance on my 17' Bigfoot later today, but I'm not sure if they're comparable.
I agree that's not much ground clearance.
Old 02-13-2016, 08:57 AM   #3
The Lil' Bigfoot has a torsion axle. so it depends on the angle of the arms. Some forum members have torsion axles that can be adjusted (raised & lowered) depending on use requirements. M
Hopefully one of them will chime in soon with more information.
Old 02-13-2016, 12:54 PM   #4
ZachO's Avatar
Trailer: Sasquatch
Montana
Ah interesting. Ok. Good because I was just coming back to say that because of the thaw we're having, my Bigfoot is parked over a melting glacier right now. I'm not getting under there until things either freeze back over, or thaw completely.
Old 02-13-2016, 04:32 PM   #5
CA
Torsion axle, teflon block
I managed to get a photo of the spot we're referring to. Ron says the axle has been lifted via the insertion of a teflon "block," which you can see in the photo.
He identifies this as a torsion axle, but says he does not see a place to make a height adjustment, which would possibly explain why the block was inserted?
I asked him how the rest of the frame looked, and he answered "old." But we don't see signs of cracks or stress... at least so far!
Also, you can see the "rat's nest" of wires he was referring to in my question elsewhere about brakes. Someone has fooled with that also, there are no blue wires, and the black wire has been disconnected and just wrapped around.
Anyway, I'm still wondering if a weird mod has been done that we should check into?
Best,
EllPea in CA
Old 02-13-2016, 06:01 PM   #6
CA
Here is another update. Ron had me jump in the trailer while he observed the frame/torsion/tire. He says the only flex is in the tire, so he expects the torsion is shot, and THAT is why the teflon blocks were installed.
Bummer.
Any advice on what/how much we need to do to fix?
Best,
EllPea in CA
Old 02-13-2016, 06:26 PM   #7
Not all torsion axles are adjustable for height. When you select your new one you can choose.
axle, bigfoot
Bumper Ground Clearance Craig D. Thompson Problem Solving | Owners Helping Owners 3 10-04-2013 08:15 PM
Question on Bigfoot ground clearance spartacus Towing, Hitching, Axles and Running Gear 27 08-29-2013 05:39 AM
Ground clearance??? jime444 General Chat 16 05-04-2011 06:21 AM
Ground Clearance for Eggs Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 10-30-2002 11:16 PM
