Listing to one side...problem? - Fiberglass RV
Old 07-11-2008, 10:56 PM   #1
JenPB's Avatar
Trailer: 1972 Compact Jr
Thumbs up
OK, the electrical is up, the propane system is complete and the water systems are ALMOST there.
Now...
The trailer lists to one side (driver's side which is the water tank side). It's about 2" lower on the driver's side rear end of frame than the passenger's side. This is when the trailer's completely unloaded (no water, no goods).
The frame APPEARS straight. Can't find any cracks in the frame or the leaf springs. Could the leaf on the driver's side just be slightly flatter than passenger's due to years of water weight on that side?
Should I bother to do something about this at this point? Or just not worry about it...
Seems to tow fantastically!
Jen
Jen
The Blog - travels and more
The Book - what we do around these parts
JenPB is offline   Reply With Quote
Old 07-12-2008, 05:34 AM   #2
Jen
Yes, one side springs can be flatter, or broken (in the middle) where you can't see it. Are all the shackles fully attached? Can you compare the arch from side to side?
How bad is the list? Half-inch, 3 inches???
Old 07-12-2008, 06:00 AM   #3
Alf S.'s Avatar
Hi: Jen... Fiberglass trailers usually list a little due to the distribution of weight from cabinets,appliances, battery placement, gas bottle and lastly just age!!! Thats not to say that it shouldn't be looked into but it can and does happen.
Old 07-12-2008, 06:02 AM   #4
Roy in TO's Avatar
I don't think you are fully awake yet Donna, JenPB provided the info in the original post.
Old 07-12-2008, 06:08 AM   #5
Gad, and I accuse others of NOT reading.
Coffee, coffee, I need more coffee!
Old 07-12-2008, 02:15 PM   #6
Roy in TO's Avatar
I don't expect anyone to function at 5 AM unless they are working the graveyard shift. I was just nudging a sleepy driver trying to keep them awake.
If coffee is what you need we better pull over and get some.
Old 07-12-2008, 03:04 PM   #7
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
My Campster listed when one of the shackles holding the leaf springs was bad, but even with that replaced it still lists a bit. Before it was more like 2-4 inches, now maybe 1-2 inches.
Old 07-13-2008, 10:33 AM   #8
Trailer: 94 Casita 16 ft
The beauty of leaf-spring suspensions is that components can be switched easily from side to side to see if that corrects the problem. They can also be rebuilt for much less cost than replacing a torsion axle (parts alone likely less than 100 bux for springs, shackles, bushings, and U-bolts).
If you go with a rebuild, you can also easily lift the entire rig to gain ground clearance if desired.
Look under the back end of any pick-up and you'll find leafs because after all these years, nothing has been developed that will take as much abuse for so little cost.
Paul from NWOnt is offline   Reply With Quote
Old 07-13-2008, 10:41 AM   #9
JenPB's Avatar
Post
Coffee error aside (I've had mine today, so I SHOULD be ok here), sounds like my trailer's not too far off. I just went out and measured (rather than eyeballed) and here are the details.
The arch in the spring measures 4 3/4" from the bottom of the frame to the top of the spring (passenger' side); 5" on driver's side. So there's "only" a 1/4" inch difference. The result is that, at rear bumper, there's a 3/4" difference betwen passengers' side and driver's side.
I don't have great eyes, so I'm surprised this difference is even noticeable to me. I think I'll go with it for now, unless someone here advises me strongly otherwise.
Thanks again, Fiberglass Friends!
Jen
Jen
Old 07-13-2008, 08:16 PM   #10
Trailer: Fiber Stream
Talking
So there's "only" a 1/4" inch difference. The result is that, at rear bumper, there's a 3/4" difference between passengers' side and driver's side.
I think I'll go with it for now...
For less than 1" of difference, I agree that it is not critical.
Old 07-20-2008, 08:43 PM   #11
JenPB's Avatar
Thumbs up
Had the water tank full, but nothing else loaded, when I headed home last night. The trailer was towing slightly SIDEWAYS down the road. I HOPE this was merely due to unbalanced load. PLEASE tell me this won't be the problem once it's all properly loaded!
In other words, if my list is less than 1" unloaded and towing fine, shouldn't I expect the same (or better) when I load it up?
Jen in Cali
7 days 'til The Big Trip - WOO HOO!
Jen
2000 Watt Yamaha vs Honda side by side Larry Harmon General Chat 13 03-05-2009 09:00 AM
Looking for "lost listing" Lorraine E. General Chat 3 02-25-2008 09:45 AM
Fishy ebay listing with a day left Classified Archives 0 01-01-1970 12:00 AM
