LiteHouse side windows. - Fiberglass RV
Old 03-14-2012, 07:17 PM   #1
Davie B's Avatar
Trailer: Lite House
I was working inside the trailer during a rainstorm tonight and realized that there was a series of drips coming from the bottom of the window gasket on the starboard side. Here's a photo of the leak.
I can't find a manufacture mark on the window. Do they look familiar to anyone?
Davie B is offline   Reply With Quote
Old 03-14-2012, 07:26 PM   #2
Hehr. You can probably fix the leak by pulling the window, cleaning up anything clinging to the aluminum frame and around the fiberglass opening and apply butyl to the frame and reapplying the window to the body. Cinch the inner "clamp ring" around the interior of the trailer and removing the squished out butyl from the exterior of the trailer... with a plastic knife. This is a standard maintenance issue with molded fiberglass trailers. YMMV
Old 03-14-2012, 07:30 PM   #3
Davie
They look like Hehr windows. Need to get it sealed or clean out your window drains. The glassed bottom in the LH holds the water and it will rot the floor.
Eddie
Old 03-14-2012, 10:03 PM   #4
Davie B's Avatar
Trailer: Lite House
Fixing some floor rot is the next big project.
Old 03-14-2012, 10:21 PM   #5
Trailer: 1976 Surfside
I think if you follows Donna's advice you will be just fine!
ken h is offline   Reply With Quote
Old 03-15-2012, 03:16 PM   #6
Davie B's Avatar
Trailer: Lite House
Thanks Donna and everybody else who chimed in. For the record, here is a link to a the Hehr RV window Service Manual.
Old 03-15-2012, 06:13 PM   #7
Dave, before you pull the window, check the weep holes on the outside... they need to be clear for water to drain and not migrate back inside the trailer. Typically the weep holes are covered with plastic covers. Take a piece of weed wacker line and run it through the holes to clear. Then, I check for leakage with a water hose.
Good luck!
windows
Uhaul Side Windows RICK H. Problem Solving | Owners Helping Owners 80 12-12-2016 06:07 PM
Changing side windows on boler to radius windows. screamin_flamesfan Modifications, Alterations and Updates 3 09-11-2013 07:59 PM
scamp side windows... nancy and steve Problem Solving | Owners Helping Owners 0 05-28-2011 10:00 AM
Side windows for Boler wanted CliveAlive Classified Archives 4 11-24-2008 10:01 AM
Boler Side Windows Kevin M Problem Solving | Owners Helping Owners 2 08-05-2008 09:02 PM
