Locating a battery monitor in 2014 Parkliner - Fiberglass RV
Old 08-03-2019, 11:36 AM   #1
Trailer: 2014 Parkliner
Virginia
Cool Locating a battery monitor in 2014 Parkliner
Hello To the group,
This may have appeared before but I could not find it in the search forum.
We bought a used 2014 Parkliner and the fellow we bought it from paid for a battery monitor which he had no idea where it is was when we asked him. We have looked for it with no success. If anyone has this in their Parkliner and can share where it is we would greatly appreciate it.
Second question is more generic, our co2 alarm chirps I think when we have the camper set on the battery setting so Im guessing the batteries are not charged enough to keep it from sounding an alarm? If we turn off the DC switch will that stop the chirping that wakes us up? We do not use the propane tanks and they are on off.
PJ
PJ47 is offline   Reply With Quote
Old 08-03-2019, 12:01 PM   #2
CO2 is carbon dioxide. You exhale that. The chirping you hear is from the propane gas detector. It will also sound an alarm if a dog lets off gas.
There is good chance it is chirping to signal that it has reached the end of its life and needs replacement. They are good for five years or so.
To keep it from sounding an alarm, the face plate should be regularly vacuumed or wiped down with a damp cloth.
Old 08-03-2019, 01:16 PM   #3
Virginia
The chirping started 2 years ago and no dog to fart
Hi
I know what the alarm is for and we do not have our propane tanks on ever and I think it only happens after we have switched our power to DC forget to turn it off, and stop at home or camping and then it must drain the batteries and after a day or two it will chirp, so perhaps I diagnosed it myself?
Old 08-03-2019, 02:24 PM   #4
Sid
Sid's Avatar
Trailer: Parkliner 2014 V6 Jeep Cherokee
It is due for replacement. We just did ours.
“You can’t go back & change the beginning but you can start where you are & change the ending” C.S. Lewis
Sid is offline   Reply With Quote
Old 08-03-2019, 03:18 PM   #5
You said it not me. And it is due for replacement.
Old 08-03-2019, 03:48 PM   #6
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
As Glenn said, it is due for a replacement, whether it is a CO or propane detector. They each have a 5 year life. Chirping can also be caused by a low battery on either a stand alone or 12V detector.
Old 08-03-2019, 06:43 PM   #7
Carl Pa's Avatar
I saw them at Walmart, for about 15$, same one
Carl Pa is offline   Reply With Quote
Old 08-03-2019, 06:48 PM   #8
What did you see at Walmart for $15? I don't see any links in previous posts and $15 is about 1/4 of what they cost.
Old 08-03-2019, 07:35 PM   #9
Not $15.... only $12...
https://www.walmart.com/ip/Kidde-Smo...B-LP2/26524563
Note that the thread discussed both CO and Propane alarms so its not clear what people were talking about, but a basic CO alarm is cheap.
Old 08-03-2019, 08:37 PM   #10
The thread discussed a CO2 ( carbon dioxide ) alarm and described a propane alarm. It didn't discuss a CO ( carbon monoxide ) alarm, which is why I wanted clarification.
I believe the OP needs a new propane alarm, which will cost substantially more than a CO alarm.
Old 08-04-2019, 07:10 AM   #11
Carl Pa's Avatar
I saw a bunch of different kinds, all kinds of prices, don;t remember which was which. I also saw them at HF. https://www.harborfreight.com/carbon...arm-70031.html. My point was you can get them all over.
Old 08-04-2019, 08:44 AM   #12
The thread discussed a CO2 ( carbon dioxide ) alarm and described a propane alarm....
No, it discussed a carbon monoxide alarm and a propane alarm. You know full well that the reference to a CO2 alarm was a mistake in naming a carbon monoxide alarm and no one was really talking about a carbon dioxide alarm. Unless of course you can show me that carbon dioxide alarms are commonly used in campers . So in sum, the propane alarm costs a fair bit more than the carbon monoxide alarm and both have finite lifetimes, usually start beeping at EOL, and are commonly available.
Old 08-04-2019, 11:14 AM   #13
Trailer: Parkliner
Hello To the group,
PJ
Hello and welcome to the Parkliner family, Let see what we can figure out for you. What is the location of the alarm that is chirping. Also, the battery monitor shold be on rhe fiberglass panel above the closet to the right of the bathroom. Most likely it is a sealevel2 monitor, black panel in color with 4 buttons on it, if I rember correctly (batt,black,gray,l.p.) should be the buttons.
AmcGee is offline   Reply With Quote
Old 08-04-2019, 11:56 AM   #14
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
The monitor in our 2016 ParkLiner is above the closet behind the screen door to the left of the main door.
battery, parkliner
To Monitor or NOT to Monitor Darral T. Plumbing | Systems and Fixtures 15 10-13-2014 07:22 PM
ParkLiner Battery Monitor and Battery Strap deryk Modifications, Alterations and Updates 23 05-12-2013 12:57 PM
Battery Monitor... solar controller monitor? LukeP Modifications, Alterations and Updates 5 05-14-2012 10:54 PM
Need help locating ensolite Perry Mac Donald Problem Solving | Owners Helping Owners 3 05-07-2009 04:22 PM
Need Help Locating Bonnie Problem Solving | Owners Helping Owners 2 06-02-2008 07:38 PM
