Looking for a/c - Fiberglass RV
Old 06-30-2007, 03:57 PM   #1
Trailer: Trillium 4500
I just bought a 78 4500 Trillium and was wondering where i can find a roof a/c for this? I'm in Saskatchewan
Thanks
AprilL is offline   Reply With Quote
Old 06-30-2007, 04:02 PM   #2
Kevin Woods's Avatar
Trailer: Former 1978 Trillium 4500 owner
Thanks
I don't know about a roof top AC but... I just saw at our local Home Depot the smallest "in the window" type AC for $89.00!! I'm tempted to rig something up.
K
Kevin Woods is offline   Reply With Quote
Old 06-30-2007, 04:27 PM   #3
Gina D.'s Avatar
West Coast USA
Can't help ya with the AC, but wanted to say "Welcome to FGRV!"
Old 06-30-2007, 04:34 PM   #4
I can't help specifically with a Trillium Roof A/C either...and I agree with Gina D. HI
However, you may want to read this topic...it's about a Scamp. It appears older molded fiberglass trailers, of all brands, have a hard time carrying the weight of a roof A/C.
1982 Scamp 13' AC Question, Install new Air Conditioner. It may give you some other ideas.
Old 06-30-2007, 07:40 PM   #5
K
ok thank you Kevin I'll have to check into it , it probably means removing a window though?
maybe the kitchen one?
Old 06-30-2007, 07:43 PM   #6
And thanks Donna and Gina!!!!
the link made me think twice about roof a/c
Old 06-30-2007, 07:49 PM   #7
Oh no, don't jump to conclusions....hopefully someone with the exact trailer you have will chime in and give a definitive answer. I just wanted you to read the link for the info. And like Kevin's A/C, a window A/C is hundreds $$ cheaper than a roof model...if that's important to you.
Old 06-30-2007, 09:36 PM   #8
Marc Barrière's Avatar
Trailer: Trillium 1976
K
I have done that with a trillium 76. It's just perfect. I installed the AC in the front windows. I connect it directly by the outside . It s cheap, works perfectly only when you need it. I used to put it under the table when I dont use it...
Marc Barrière is offline   Reply With Quote
Old 07-01-2007, 02:37 AM   #9
do you have any pics of how you put it in? i'm camping and trillium stupid lol
thanks in advance
Old 07-01-2007, 03:04 PM   #10
Trailer: Fiber Stream
Talking
The following Link shows how I did mine:
My removable window air conditioner.
A Trillium has louvered windows, so with some modification, this might work as a permanent installation. You'd have to remove the glass louvers; but try to keep the window frame intact. Make the vertical "L" brackets long enough to attach to the window frame with screws or nuts & bolts. You probably won't have to radius cut the corners...
Mine is NOT a permanent installation. Also, I have discovered that 5000 BTU's is not adequate in a 16' uninsulated egg when you are in Palm Springs in June where it is [b]113* and no shade in sight.
