Looking for a manual - Fiberglass RV
Old 04-06-2016, 09:10 AM   #1
Trailer: 1999 Kustom Koach-Westwind
Hello
I live in Alberta Canada and just recently purchased a 24.5 foot RV
here. I'm wondering if anyone might have an owners manual they could copy and e-mail me.
The RV is a 1999 Kustom Koach -Westwind.
My e-mail address is cruizin2@shaw.ca
Thanks and happy RV'ng to everyone-the season has started early here in Canada
Larry
cruizin is offline   Reply With Quote
Old 04-06-2016, 09:27 AM   #2
Larry, this forum is dedicated to the all-molded towables. I see your 1999 Kustom Koach is a completely different build type.
You may have better luck gaining the information you seek at:
http://www.IRV2.com
or the Open Road Forums at RV.net
Best of luck
Old 04-06-2016, 09:55 AM   #3
Hi Donna
What do you mean by all-molded?
Old 04-06-2016, 10:05 AM   #4
Originally Posted by cruizin View Post
Hi Donna
They're built like fiberglass boats. Typically two halfs joined together to create a "shell." There's only that one seam and no internal framework. No flat panels are affixed to create the exterior walls.
I hope this helps.
Old 04-06-2016, 10:40 AM   #5
Hi Donna
No not really. Why is my RV different?
Larry
Old 04-06-2016, 11:05 AM   #6
Maybe I'm the one that's misunderstanding. When I Googled 1999 Kustom Koach -Westwind, this is what displayed
Maybe you can help me help you if you can post a picture of your 1999 Kustom Koach - Westwind.
Old 04-06-2016, 12:48 PM   #7
Hi Dona
The picture looks like ours except for the front. Our is more rounded.
So I still do not understand why ours is different from other Rv's
Larry
Old 04-06-2016, 02:19 PM   #8
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Yours is "stick" built, like a house. Studs (wood or aluminum), aluminum or fiberglass siding, possibly a fiberglass nose.
This this group celebrates trailers that are made in molds out of fiberglass and get their body strength from that.
If it has a frame it's not molded. Yours is not different from other RVs but it is different than ours.
Wait a minute....Is this a troll? Maybe I'm falling for it.
Without adult supervision...
Also,
Old 04-06-2016, 02:47 PM   #9
Hi
No I'm real -just a novice RV guy
Larry
Old 04-06-2016, 04:51 PM   #10
Here Larry, this may explain how our trailers are built. This is an Escape 5.0TA coming out of the mold. Just like they build fiberglass boats.
Old 04-06-2016, 04:54 PM   #11
What we call conventional or "stick-built" RV construction starts with a (usually) steel chassis. The walls and ceiling are framed with wood, steel, or aluminum and covered with some kind of exterior skin (commonly aluminum or fiberglass sheets).
All-molded construction starts with a similar chassis, but the entire cabin- walls, ceiling, and sometimes the floor as well- is formed by laying up fiberglass in a mold. Typically two sections (upper and lower or left and right) are then bonded together so that the whole cabin becomes a single, self-supporting unit. There is no framework inside the walls, similar to a fiberglass truck topper. Inside some are finished out with molded fiberglass cabinetry as well; others have conventional wood cabinetry.
You can see a molded fiberglass trailer being put together in the promotional video on the Scamp website (starting at about 7:00).
Advantages of all-molded fiberglass construction include (1) lack of exterior seams, (2) light weight, (3) fewer leaks, (4) aerodynamic shape.
Hope that helps a little to clarify what makes our "egg trailers" different!
Old 04-06-2016, 05:17 PM   #12
Hi Donna
Yes that really explains it for me-thanks
Off to find a manual-Ill use the sites you sent me
Have a great evening
Larry
Old 04-06-2016, 05:22 PM   #13
Best of luck Larry, truly!
Hi, Looking for an electronic copy of the Casita Owners Manual 17' 2007 unit Scott B. Problem Solving | Owners Helping Owners 3 07-08-2012 02:24 PM
Looking for Jayco 1006 (1995) wiring manual thomasokcmom Problem Solving | Owners Helping Owners 2 07-02-2012 07:25 PM
New Surf Side owner looking for owner's manual Lake Surfer Problem Solving | Owners Helping Owners 3 06-14-2012 08:49 PM
Looking for a Wave 3 Owner's Manual peterh Problem Solving | Owners Helping Owners 10 11-06-2008 09:56 AM
