Loose Scamp rivets - Fiberglass RV
Old 06-12-2013, 10:54 PM   #1
Alaska
Loose Scamp rivets
We recently got our 2006 16' Scamp. The previous owner drove hundreds of miles on rough gravel roads in Alaska and there are numerous loose rivets. Do I need special rivets and tool or will something else work?
Tom Smayda is offline   Reply With Quote
Old 06-12-2013, 11:43 PM   #2
Perry J's Avatar
Aluminum rivets are available at most hardware stores.
You will need two sizes 3/16 x 3/8 to 1/2 inch grip range and 3/16 x 1/4 grip range.
If you are replacing the upper cabinet rivets you will need Acorn nuts.
It the curtain rod brackets are loose you need 1/8 x 1/2 inch grip range.
If you need snap caps and bases go to prodec.com and click on snapcaps.
he page that comes up will show both sizes you need.
It's much less expensive ordering the caps from prodec than Scamp.
A hand rivet gun is all you need and are also available from most hardware stores.
Good luck, several years ago I bought a 16' Scamp that needed every rivet replaced.
John
scamp
Scamp 13 77' Rivets Chita Problem Solving | Owners Helping Owners 11 02-22-2013 04:15 PM
Scamp Air Conditioner housing loose Weinel, Alan Problem Solving | Owners Helping Owners 0 09-08-2009 09:42 AM
Scamp Trailers and Rivets Matthew A Care and Feeding of Molded Fiberglass Trailers 7 08-02-2009 02:11 PM
Scamp and the pop rivets Bruce M. Care and Feeding of Molded Fiberglass Trailers 25 05-20-2008 05:57 PM
Replacing pop rivets in a Scamp Sonny Problem Solving | Owners Helping Owners 7 10-06-2006 05:06 PM
