Old 06-19-2012, 06:43 PM   #29
dylanear's Avatar
Trailer: 2001 Scamp 13'
[QUOTE=dylanear;315900]
Originally Posted by Roy in TO View Post
Two 6V would have to be in series to get 12V, I don't think you'd want two batteries in series 8 feet apart.
But I'll check with the charge controller specs and see if 2 x 6V would work.
Seems the Morningstar Duo (which I just ordered) will do two SETS of batteries, each set could be a pair of 6V I suppose.
dylanear is offline   Reply With Quote
Old 06-19-2012, 07:43 PM   #30
Trailer: 1973 Hunter Compact II, 1983 Starcraft 14 p/u, 1994 Lil' Bigfoot, 2013 Coleman 17' Hybrid (Kids use)
As long as we are spending your money; if you get two 6 volt batteries, get Golf Cart batteries, they are designed for more abuse and discharge/recharge cycles than starting or marine type batteries.
Old 06-19-2012, 09:47 PM   #31
dylanear's Avatar
Not sure what batteries I'll end up with at this point, but was thinking lately of two type 31 120ish amp hour AGM deep cycles. Only 20 lbs more on the tongue, but lot's more amp hours compared to the 80ah on my current grp 24 flooded. I'll look at the 6Vs and compare at some point. The AGM seem like the thing for me. I know I'll never take proper care of flooded batteries over the long haul, and perhaps more importantly, I want to put one battery in the cabin, so AGM is a requirement there. Not the cheapest option, but I kill batteries dead by blinking, so I may even come out ahead in the long run with the more durable glass mat tech.
battery
How Does a Battery Cut-Out Switch Work? Tamid Problem Solving -- Owners Helping Owners 3 07-28-2010 09:31 AM
Can Low Voltage Fry the Breaker Switches? Adrian W Problem Solving -- Owners Helping Owners 4 07-22-2008 11:55 AM
Low-Voltage Disconnect - Anyone Using One? dkdavies Problem Solving -- Owners Helping Owners 6 10-06-2007 05:36 PM
Is it ok to mount a battery isolation (cut off) switch inside the trai Curtis F. Problem Solving -- Owners Helping Owners 8 07-05-2007 06:46 PM
Low Voltage Lighting Darrel Smith Modifications, Alterations and Updates 9 05-17-2007 11:23 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
