LP/CO Detector - Page 3 - Fiberglass RV
Old 04-22-2015, 03:01 PM   #29
LP detector should be near the floor as LP sinks.
Instructions for CO detector call for it to be located about three feet above the floor.
So, I'm not sure a combo unit ( and they are sold ) is the best solution.
I'd be inclined to go with a combo smoke/CO detector and a separate LP gas detector.
Old 04-22-2015, 03:18 PM   #30
mgellar's Avatar
Trailer: Scamp 16' Oak Deluxe Layout A - "Kiwi"
Maryland
Thanks. Too bad the CO detector supplied by Scamp does not include a smoke detector. With LP needing to be by floor, that probably shouldn't be combined with smoke detector. Seems like LP is more important.
mgellar is offline   Reply With Quote
Old 05-06-2015, 05:52 PM   #31
CampyTime's Avatar
Trailer: Scamp 13' Standard
I added a hard wired propane detector to my scamp 13. Searched long, and could not find a combo unit (one that took batteries at least). I've posted pics of my unit before, but I installed it on the front of the bunk bed fiberglass on fridge side. Fridge door does not hit it. I feel safer with both co and lp detectors in the rig.
Old 08-24-2016, 10:58 PM   #32
Trailer: 1975 Boler
Quebec
Not sure whether I should ask my question here or start a new thread. We'll see.
I understand that the answer to one of the original question is: hardwire your propane detector.
I'll be using a small electrical space heater when we have electricity and try our propane heater in a setting where we won't have electricity. I'm not equipped with 12 V so is it possible to get a battery propane detector? Any suggestions?
Thanks!
Uncle Cereal is offline   Reply With Quote
Old 08-25-2016, 03:28 AM   #33
Borrego Dave's Avatar
Trailer: Casita SD17 2006
I'll be using a small electrical space heater when we have electricity and try our propane heater in a setting where we won't have electricity. I'm not equipped with 12 V so is it possible to get a battery propane detector? Any suggestions? Thanks!
That question came up recently. Seems that all CO/LP monitors are powered off the 12V (or 110V for your home) house battery but can have a 9V battery backup. Think they said the 9v backup would run around 12 hours. Another thought for 12v power for a monitor, you might look into a small 12v battery like those used in emergency lighting applications. There're small, 3"x4"x6", 5 pounds, rechargeable and with a lighted LED on/off switch you wouldn't be draining it for the times you're not running the heater.
Borrego Dave is online now   Reply With Quote
Old 08-25-2016, 06:46 AM   #34
Originally Posted by Borrego Dave View Post
T... Another thought for 12v power for a monitor, you might look into a small 12v battery like those used in emergency lighting applications...
That might work...
Similar batteries are used for alarm system back-up power and come in different ratings, but 8 amp-hours is typical.
The Kiddie gas Alarm I have draws about 75 milliamps (1.8 amps a day) so the 8 amp hour battery should power it for 106 hours or a little under 4 1/2 days. However I would not plan on more than two (maybe three) days out of it in actual practice.
Even with my group 27 battery, the detector runs the battery down enough that I hook up the charger every few weeks (or flip the battery master disconnect switch to the off position, which is my go-to solution when the trailer is stored and the propane tank is off).
Partnered with a solar charger and a 10 watt panel it would be feasible to extend that time, perhaps indefinitely. Even a 5 watt panel might be enough if you get good sun for long days but 10 would be better in practice.
...There're small,... and with a lighted LED on/off switch you wouldn't be draining it for the times you're not running the heater.
If you are talking about a rig with propane lines going through the camper, then I would run the detector anytime the main propane tank valve was on regardless of what appliances are running or not.
Of course a lot of people don't use propane detectors at all. If your sense of smell works well and you can detect the added odorant, you might consider the risk/reward of skipping the detector for short term outings. But of course it is safer to have the detector and I would not recommend anything else.
Old 09-04-2016, 01:26 PM   #35
Roy in TO's Avatar
Originally Posted by David Tilston View Post
I use a BW Technologies Microclip 2. Part number: MC2-XW0M-B-NA.
What is one worth Dave?
What Smoke Detector? curtis c Problem Solving | Owners Helping Owners 11 04-09-2009 02:52 PM
Casita Propane Leak Detector Alarm David A. Problem Solving | Owners Helping Owners 4 02-11-2009 08:26 AM
Lie detector Morgan Jokes, Stories & Tall Tales 0 07-04-2008 06:31 AM
CO/gas monitor questions also smoke detector Q. Bobbie Mayer Problem Solving | Owners Helping Owners 14 12-01-2007 06:04 PM
Propane detector and Carbon Monoxide detector. Yves Pelchat Problem Solving | Owners Helping Owners 6 02-05-2006 10:28 PM
» Virginia Campgrounds
