LP problem - Fiberglass RV
Old 04-28-2010, 05:56 AM   #1
Trailer: Scamp 13 ft
I just recently purchased a 1999 13' Scamp. It has the 2 burner Suburban LP stove. I can't get it to light off very well. I know the LP tank is not the problem because I switched to a tank that I was sure was good ( both tanks have the OPD valve ) and the symptoms were the same. One burner will barely light but the flame is weak and if I try to light the other burner, the first one goes out. The stove hasn't been used for some time. Do the lines get clogged and will blowing them out with compressed air help? My local LP place said they could bench test the regulator so I will take it to them. Do the orifices in the stoves get plugged?
I love the Scamp and am planning a big trip to Alaska next year. Any help will be appreciated.
Jon Kilpatrick is offline   Reply With Quote
Old 04-28-2010, 07:40 AM   #2
DonDeutsch's Avatar
Your doing it correctly, start at the tank and work towards the stove.
DonDeutsch is offline   Reply With Quote
Old 04-28-2010, 10:31 AM   #3
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Also, when opening the tank, remember to open it VERY slowly. Opening the valve too quickly could cause the OPT valve to trip. Results would seem to indicate similar issues you are experiencing. Once that valve is tripped, the only way I know of to correct it is to undo the trank from the trailer (and the hose), slowly upend the tank and then carefully re-install. Do a leak test on the reinstalled tank for safety sake. Another possible cause could be spider web/dirt, junk build up in the line.
I would NOT consider blowing compressed air into the line, as the air contains moisture which is definately NOT needed in any fuel line.....
Old 05-08-2010, 06:28 AM   #4
I took the regulator to a local LP business and had it bench tested. It failed. The service man said that it was OK to use compressed air to blow out the lines since if there was a blockage, any moisture in the air would be the least of my problem. He said that they use compressed air to leak test any new installation they do. He advised starting from the stove end of the line because sometimes there is some nasty debris and odor coming out of the line. I blew the lines, installed the new regulator, and now the stove works great.
Old 05-08-2010, 06:47 AM   #5
Doug Mager's Avatar
Great news, a relative easy fix. for the update. Another piece of knowledge gleemed from this great website....
Old 05-08-2010, 10:35 AM   #6
Mike Bromley's Avatar
Trailer: 1973 Boler 1300 (Glass-Fab
Good news. Regulators are often the problem, wouldn't you say?
Methyl hydrate is often used to purge lines of debris and residual LP condensate, because of its dessicating properties.
Just re-emphasizes the importance of keeping your propane system healthy.
Mike Bromley is offline   Reply With Quote
problem with PC Legacy Posts Jokes, Stories & Tall Tales 16 02-02-2003 09:15 PM
New AC problem Legacy Posts Problem Solving | Owners Helping Owners 7 11-10-2002 11:22 PM
