Lubricant for window hardware - Fiberglass RV
Old 09-10-2013, 12:40 PM   #1
One of the window crank mechanisms on our 76 Trillium is a little stiff. I see some plastic caps on the crank mechanisms that in some cases are missing, leaving an open hole. I could squirt something through these or at least around the shaft where it enters the mechanism, hoping it will work through. Does anyone know if these are just metal gears or are they some more exotic product that might be damaged by the wrong lubricant? What's best?
Randy J. is offline   Reply With Quote
Old 09-10-2013, 12:47 PM   #2
A bit of machine oil may take care of it.
Avoid products like WD40 as they are not a lubricant but simply dry things out more.
Old 09-10-2013, 03:46 PM   #3
Graphite
Old 09-11-2013, 08:34 AM   #4
fusedlight's Avatar
Trailer: 16' 1998 Scamp
I use a DuPont (I think) Teflon spray. It doesn't get messy like graphite or molly and seems to do the job.
fusedlight is offline   Reply With Quote
Window seals & hardware for 76 Scamp tilt out windows Jenny W. Modifications, Alterations and Updates 42 07-31-2013 12:11 PM
cabinet hardware Shaidah Modifications, Alterations and Updates 6 02-04-2012 10:28 PM
TAKEN ~ Scamp hardware KamperBob Classified Archives 2 06-07-2007 05:30 PM
Window seals & hardware for 76 Scamp tilt out windows Steve Thomas Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
