lubricating atwood stabilizer jacks - Fiberglass RV
Old 04-11-2017, 04:54 PM   #1
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
What do you use to keep these lubricated? I'm thinking grease or oil will just attract and hold dust and dirt given their location. Is a dry lubricant like graphite better ? WD-40? What is your experience?
P.S. Can you tell from my multiple questions that spring has finally arrived in Vermont? Bit of snow still on the north side but the Scamp is now uncovered from her long winter nap and being readied for the season. Norm has created an addiction and we'll be Newfoundland-bound next month.
WDavidG is offline   Reply With Quote
Old 04-11-2017, 06:33 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
I use white lithium grease for all outdoor threaded things; should work fine in these too. Comes in a spray can with a dispensing tube like WD40 at Loews or Home Depot
Charlie Y
Old 04-11-2017, 06:49 PM   #3
Originally Posted by WDavidG View Post
What do you use to keep these lubricated? ...
Manufacturer says to clean and oil very six months but does not say what oil to use... (probably because it does not much matter if you clean them every six months ) Trailer Hitch Instructions For DrawTite, Reese, Hidden Hitch & More - etrailer.com
Old 04-12-2017, 09:45 AM   #4
Thank you - Charlie, this info helps me.
Eric
HawkBoler72 is offline   Reply With Quote
Old 04-12-2017, 10:15 AM   #5
Vermont
great idea, thanks Charlie. It's now on my HD shopping list.
Old 04-12-2017, 10:53 AM   #6
Motorcycle chain lube spray works well in applications like this. sprays on thin and wicks in tight places and then gells like a soft grease. Made to stay in place once applied.
https://www.walmart.com/ip/DuPont-Te...11-oz/16672659
Old 04-12-2017, 12:36 PM   #7
Trailer: 2016 -13' Scamp
Massachusetts
Ditto this! Great for sliding patio doors and screens, as well.
Just uncovered the Scamp which had stabilizers down for the winter. They retracted and folded up with ease. One less hassle and very unlike other lubricants that I first tried.
herons is offline   Reply With Quote
Old 04-12-2017, 09:40 PM   #8
Trailer: Trail Cruiser
White lithium works great and I travel a lot on gravel roads.
Old 04-13-2017, 09:57 AM   #9
Trailer: 1984 UHaul CT13
Agree with Mike & Charlie.
keekers is offline   Reply With Quote
Brackets for Stabilizer Jacks Jane D. Problem Solving | Owners Helping Owners 9 09-09-2011 04:10 PM
Stabilizer Jacks jimtesla Care and Feeding of Molded Fiberglass Trailers 21 06-19-2010 02:39 PM
Stabilizer Jacks for a Lil Bigfoot Carl G Towing, Hitching, Axles and Running Gear 2 05-10-2009 07:28 PM
Cleaning up the stabilizer jacks Per Walthinsen Modifications, Alterations and Updates 1 04-12-2006 10:13 PM
Stabilizer Jacks Legacy Posts Modifications, Alterations and Updates 17 05-08-2003 05:04 AM
