Make door frame water tight - Fiberglass RV
Old 05-13-2017, 06:17 AM   #1
Carl V's Avatar
I took the door assembly off my trailer (Trillium 5500) to fix wood rot on the floor.
Now I'm looking for something to seal the corners of the door frame.
It is made out of aluminium extrusions, similar to a jalousie window, but welded at the corners.
Now the welds have cracked, and they can let water pass behind. The frame is still solid but not water tight.
When I resealed my windows last year I noticed there was some kind of sealant in the corners of the jalousie windows.
What is this stuff? Window glazing putty?
I'm not familiar with this.
Would this be a good option to seal the corners of my door frame? (the whole door assembly is sealed to the trailer with butyl tape just like a window).
I need something that will not not crack again. It has to endure some flexing, as there is some when someone climbs on the trailer.
I need something durable, as any leak will not be visible, and will end up damaging the floor and the doorstep support structure, which is right under inside the "pontoon" and made out of wood (just had to fix all that due to wood rot).
Epoxy?
FG resin?
Sikaflex or similar?
Open to suggestions as to how to seal these corners.
Thanks
Parking in a tight spot Bob Radenbaugh Problem Solving | Owners Helping Owners 19 11-23-2007 02:55 PM
Rivets in tight spaces Isaac M Care and Feeding of Molded Fiberglass Trailers 2 06-26-2007 07:21 AM
Tight spot Greg Yother Care and Feeding of Molded Fiberglass Trailers 17 04-16-2007 06:30 AM
Tight Quarters in your 13' Egg? Frederick L. Simson General Chat 8 01-17-2007 07:44 PM
Tight Before Christmas Des Nolan Jokes, Stories & Tall Tales 1 12-14-2005 12:18 AM
