08-09-2018, 07:57 PM
#21
Puget Sound, WA
Originally Posted by Jim Bennett
The forum would only **** out what I really want to say, so just use your imagination, Mike.
Wow, rough crowd, a fellow can't hardly say anything around here without getting in trouble!
08-10-2018, 08:25 AM
#22
When I google "smartened futon", it takes me right back here...
It is a unique invention, for sure!
08-10-2018, 09:28 AM
#23
A smartened futon connects to your electronic device via Bluetooth. When you fail to respond to the Netflix prompt, "Are you still watching?" it automatically folds down to bed mode.
#NoMoreChiropractors
08-10-2018, 09:30 AM
#24
Keep trying.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
08-10-2018, 09:32 AM
#25
Originally Posted by Jon in AZ
A smartened futon connects to your electronic device via Bluetooth. When you fail to respond to the Netfllix prompt, "Are you still watching?" it automatically folds down to bed mode.
Eliminates stiff necks and sore backs.
Man oh man, a guy makes just one wee error. My biggest mistake obviously was not proofing it before it was caught.
I woulda been all over it as well.
2017 Escape 5.0 TA
08-10-2018, 06:10 PM
#26
Puget Sound, WA
Ooh, ooh! I definitely want that!
Being that it incorporates so much leading-edge tech, I will be looking for one with a "new every two" plan!
08-15-2018, 11:06 AM
#27
1/8" pipe size is measured on the inside diameter. So it is bigger than 1/8" on the outside.
Hope this helps any confusion.
Bill Kelleher
08-15-2018, 03:13 PM
#28
FWIW, All of the propane tubing/fittings I've seen installed on any of these trailers is 3/8". There ya go.
08-15-2018, 05:20 PM
#29
But not the test ports... which was what was originally asked.
08-15-2018, 09:10 PM
#30
Trailer: Roamer 1
Smith Valley, Nevada
Originally Posted by gordon2
Yep. Trailers often have either a 1/2" black iron main gas pipe or a 1/2" copper tube main line. The 3/8" copper tube "drops" feed each appliance. Gas test ports are typically located on the gas valve and are 1/8" pipe. This is a pipe thread plug, usually with a socket head drive and about 3/8" in diameter. 1/8" pipe is about 3/8" OD.
The manometer is connected with a 1/8" pipe X 3/8" tube barbed fitting that is screwed into the port where the plug was removed. Then a 3/8" ID rubber hose connects to the gauge. Once the connection is made, start the appliance and measure the gas pressure while the appliance is running.
08-17-2018, 11:37 AM
#31
Trailer: Sasquatch
Montana
And my manometer was delivered today so next week I should be able to test! Will be house sitting again so I can really work on stuff.
