maxxair fan installation. - Fiberglass RV
Old 08-02-2014, 07:46 PM   #1
Trailer: Escape 5.0 TA
I just installed a maxxair 5100k fan on the roof of my Casita. My ceiling/roof is about 7/8" thick and the trim for the interior is supposed to be screwed to the ceiling. But...in a Casita the ceiling is foam backed carpet....nothing to screw to. Has anyone else dealt with this issue and what did you do?
Thanks for any suggestions!
Steve
starbrightsteve is offline   Reply With Quote
Old 08-02-2014, 08:58 PM   #2
deryk's Avatar
New Jersey
Steve my ParkLiner's ceiling is similar, carpet and bubblewrap insulation. Mine had a wooden trim ring on the inside that is screwed up into the fiberglass just along the inside edges of the opening in the ceiling...covered by the hatch fan when it is installed...I kept it the same...are you adding a new hatch or upgradeing? I used the white trim ring from my original fantastic fan...it was a close enough fit.
deryk
Old 08-02-2014, 09:05 PM   #3
Steve not sure on a max air but on a fantastic fan they give you a 1/4foam gasket . Buy a 24x24 sheet of 1/2 inch plywood and use that gasket as a template and cut the ply in one solid piece table saw is the easiest way but you can do it with a jigsaw or something similar .place that piece on the ceiling and screw down from the roof . Drill a small pilot hole first as this will allow the screws to pull the ply tight to the ceiling have someone hold the plywood from inside but make sure you don't drill through there fingers .the inside trim ring should then cover the plywood with only the 1/2 inch edge showing
Mikmay is offline   Reply With Quote
Which Model Maxxair Fan? Huck Care and Feeding of Molded Fiberglass Trailers 18 07-26-2014 10:06 AM
Added a MaxxAir Fan to my ParkLiner today! deryk Modifications, Alterations and Updates 20 04-16-2014 11:27 PM
MaxxAir Fan Mate 850 vs. Ultra Breeze CampyTime Modifications, Alterations and Updates 11 12-31-2013 11:12 AM
Has anyone put a Maxxair II on a Burro or a Uhaul ? Rusty01 Problem Solving | Owners Helping Owners 0 08-29-2010 08:00 PM
Maxxfan from Maxxair Yves Pelchat Modifications, Alterations and Updates 4 06-18-2006 11:57 PM
