Maybe a Front Window Leak? - Fiberglass RV
Old 07-12-2007, 08:52 AM   #1
efawcett's Avatar
Trailer: 13 ft Scamp
Hi All,
I searched the forums but couldn't find specific's....
After a heavy rain yesterday I noticed water in my 13' Scamp. Specifically it was along the front wall only, under the front compartments. Being a really new Scamp owner I'm not sure where to start?
I immediately assumed it must be coming from that huge front Plexi-window and seeping down between the outside shell and rat fur/insulation.
Historically, is that a good place to start the troubleshooting process? What kind of potential leak causing warning signs should I look for?
Appeciate all the help I've received here, trying to get ready for our first trip next week.
Eric
efawcett is offline   Reply With Quote
Old 07-12-2007, 10:30 AM   #2
Greg A's Avatar
Hey Eric,
Look at the rubber front window channel where it meets. After a bit this tends to shrink and there is a gap of about 1/8" that you need to caulk. Avoid using silicone caulks, use 3M marine caulk you can get a wally world. It could possibly be the belly band, but I'd eliminate everything else up there first. If you have overhead cabinets seal those screw points as well. Anything that is coming through the shell in that area re-seal it.
You'll probably want to check the plywood decking up there for rot if the leak has been there for awhile.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 07-12-2007, 11:13 AM   #3
Suz
Suz's Avatar
Look at the bottom of the window on the outside and see if you don't have some small weep holes. They may be covered with little plastic "hoods." These can get clogged with dust and cause them to overflow into the inside. A good cleaning with weed wacker cord can often solve this problem. This may not be the cause, but it's sure the easiest to start with.
Even those I know this, even I had this problem recently. First thing I did was check the channel, and even though it seemed dry, I cleaned them anyway. Still leaked. It wasn't until after I got home that I realized that I actually had a dual problem. The side emergency window gasket was a little old and dry so it allowed too much rain in during a series of storms. After I cleaned out the weep holes again and it still did it, I felt like it was finally time to remove the window and redo it. I also decided to replace the gasket while I was at it. That was when I finally realized that there was a second set of weep holes on the emergency windows. A new gasket and a thorough cleaning of the second set solved my problem. I used a hose with a sprayer on it and no leak!
Suz is offline   Reply With Quote
Window Leak cyndi H Problem Solving | Owners Helping Owners 22 06-06-2010 02:59 PM
roof window leak in Compact Jr. Tami Problem Solving | Owners Helping Owners 5 02-10-2009 08:44 AM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 07:21 AM
Front Window Randy Bishop Problem Solving | Owners Helping Owners 3 05-11-2007 05:45 PM
Front window cover Legacy Posts Problem Solving | Owners Helping Owners 10 06-05-2003 08:22 AM
