10-06-2012, 11:23 AM
Trailer: Newbie owners of TrailMite
Memory Foam Mattress topper?
Good Morning!
So my question is: When your bed is not exactly the "right" dimensions for a real Full sized bed, what have you done that made the mattress topper fit correctly? I was thinking of cutting the edges, but wondered if someone has come up with a better answer?
I am looking at the Costco memory foam with gel mattress topper and my "full" bed is too wide as a twin and too narrow as a full, so the topper is either too small or too large. I was electing to go for a full and cut it down. What have others done and what did you use to cut it? (Thinking of an electric knife, like I did the cushion foam, though the first electric knife broke after the cushions were almost done).
Thanks for any thoughts.
10-06-2012, 12:54 PM
Trailer: 1983 13 ft Burro
We just cut the topper to fit and all was good
10-06-2012, 12:56 PM
Did the same as Jim and all was well also.
10-06-2012, 01:38 PM
Trailer: Escape 19
I have no experience with cutting down mattresses, so can't help you there. I do know that a lot of professionals who cut down foam rubber and styrofoam use long sharp razor knives with a slow slicing cut. Don't know if that would work with "memory foam with gel", though...
10-06-2012, 02:23 PM
I have never had to cut one to fit yet,memory foam is pretty flexible and may be able to conform to your less than perfectly sized bed space?
10-06-2012, 05:07 PM
Trailer: Escape 17 ft Plan B
The best device for carving memory foam (other than a hot wire cutter) is an electric carving knife.
10-06-2012, 05:45 PM
I used a strait edge on top, a board underneath, and a utility knife. Worked ok but I bet the electric carving knife is better. I have heard that recommended for other types of foam as well. Raz
10-06-2012, 06:47 PM
Trailer: '84 13' Scamp & '14 homebuilt Benroy Teardrop
When fitting a mattress that was 1.5" memory foam atop 2.5" regular foam for my teardrop trailer, I knew I had to cut it in half lengthwise in order to make it easier to insert and remove. First, I tried cutting it in half with a filleting knife...lousy results. I cleaned up that edge and finished the job with an electric knife...much better results. Just my experience.
Lil M.
Updates and improvements to LilScamper here
“When one tugs at a single thing in nature, he finds it attached to the rest of the world.” ― John Muir
10-06-2012, 07:08 PM
Trailer: Trillium 4500
The last one I did I just used scissors, previously however I used an electric carving knife like the pro's use.
10-07-2012, 11:13 AM
Trailer: 2015 Escape
I think I'd worry about the gel part. Is it something that could/might leak out and get where you might not want it?
10-07-2012, 09:58 PM
Trailer: 2011 Scamp 13'
Bedding - (see photos) is the most challenging for storing. Most of the time we keep the bed set up in good weather. I made a mattress topper out of a 2" Queen size thermafoam topper that we bought from Target. I made a pattern by tracing the cushions on big sheets of brown paper (comes on a roll.) I cut the foam with a sharp, good quality bread knife. The knife is about 12" long. Use short back and forth movement, much like an electric knife. I did need to piece one piece. Simply apply contact cement to each edge, wait for them to dry, butt the edges carefully (You only get one try.) The mattress cover is composed of two 23" wide strips covered with 100% cotton knit (think t-shirt fabric) custom covers that double as sheets and zip off for washing. These each can be rolled up and secured with a nylon strap. They fit perfectly in the hatch under the bench.
10-08-2012, 06:16 PM
Trailer: Burro 13'. 1982
Montana
Gilda........what did you do with the seat cushions when you "made the bed"?
10-08-2012, 06:29 PM
Trailer: 1987 Bigfoot 13'
What a great idea, I'm adding another one to my to do list
10-08-2012, 09:32 PM
I have a 3" memory foam topper I bought at Costco and the corners just mould into the rounded corners with no problem.
10-09-2012, 09:16 AM
Well I'll try this first of course, but I didn't want it bunching up in the corner and being lumpy, or hanging over the side as it is larger (supposedly, we'll see when I get it out of the box )
Then If not, I will cut it, but didn't know how memory foam with gel beads cut...we will see. I'll post here how it works and if the electric knife worked
Thank everyone for your input!
10-13-2012, 06:13 PM
In answer to your question, "What do you do with the cushions when you make the bed?", the mattress topper is simply placed on top of the cushions.
10-15-2012, 01:46 PM
What worked for me on memory foam cutting etc
Well, I let the memory foam sit and expand for a few days. It shoved itself up the sides of the rounded corners of the trailer and stuck out, so I marked the corners with a sharpie and then used an electric knife to cut off the excess. I just held the foam up so I wouldn't cut the cushions below and followed my sharpie pattern. It cut like butter! Much better than the regular foam I cut for the cushions. Here is a picture I did after cutting it and here the bed is after I made it. Worked great!
As to worrying about gel beads leaking out, no problem. Gilda, I love how you cut up yours and rolled it up. I'll keep that in mind if I ever want to remove and store the bed. We plan on using it as a bed most times and using the front as the permanent 2 person dinette.
10-19-2012, 03:44 PM
Why did you decide to split them that direction? Was it for storage ease?
10-19-2012, 05:32 PM
Good question! We sleep crosswise in the trailer (side to side) since that is the longest position. We each have our own "side" of the bed and know when one is "encroaching" on the other's side (not hard to do). (We actually love to "encroach"). More importantly, by placing the cushions this way we do not have to feel the crosswise seams that would result if we mimicked the original jigsaw of dinette cushions. I have to say the middle division is never annoying as the cushions are SO comfortable. The two pieces fit nicely under the dinette hatch when rolled up.
10-19-2012, 07:00 PM
I guess I'll finish cutting and glueing the foam to the correct size and then see if I need to cut it in half to store it. I was thinking I would leave it whole if possible
