Metal pole removal from scamp RV dining table - Page 2 - Fiberglass RV
Old 04-11-2015, 08:26 AM   #15
When I got home I tried using a monkey wrench which did not work. I wound up taking the metal base plate from under the dining table off ( stuck to the vertical tube support ). The base of the tube was now exposed through the base plate. After soaking the stubborn cylinder in some screw loose once again, I put it and the metal base in a vice and using a rubber mallet hit the end two or three times. It popped right off.
I coated the cylinder with stopcock grease to ensure that it would be easier next time I wanted to get the table removed from the cylinder. Hope I'm right about that.
I want to thank everybody for all their expertise. You all had some really great ideas out there thank you.
robertmarchiony is offline   Reply With Quote
Question on Re-installing Dining Seats and Bunk Bench Kirby Modifications, Alterations and Updates 0 03-14-2014 06:01 PM
Looking for a bigger dining table billkateposs Modifications, Alterations and Updates 18 10-08-2013 07:51 PM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
Trillium 1300 - Information on shelf over dining table Booker B. Problem Solving | Owners Helping Owners 12 04-20-2008 09:54 PM
Wanted: Trillium Dining Table hardware Booker B. Classified Archives 4 03-25-2008 02:36 PM
