Microwave question - Page 2 - Fiberglass RV
Old 09-01-2012, 06:20 AM   #21
Raz
Raz's Avatar
Originally Posted by David Tilston View Post
OK they do make a 12 VDC microwave. A couple of observations though:
No power rating
Very small
Very expensive
I'm thinking a $100 inverter with a $50 microwave is a better plan. Cheaper too.
I don't disagree at all. I was curious and surprised to find one. I found a 12v. toaster too. Go figure. I think these things are aimed at the long haul trucker, not RV folks. Raz
Microwave Oven Specifications
Voltage: 120 Volts AC/12 Volts DC
Power Rating: 660 Watts
Exterior Height 11” (279mm)
Exterior Width: 15” (381mm)
Exterior Depth 10” (254mm)
Cooking Cavity Width 10” (254mm)
Cooking Cavity Depth 7” (178mm)
Weight: 14lbs (6.35kg)
Shell: Reinforced ABS Plastic
Base: Rubber Footings
Power Port Specifications:
Voltage: 12 Volts DC
Power Rating: 70 Amps
Dimensions: 5.5”(L) x 2.9”(W) x 2.3”(H) (140 x 74 x 60mm)
Total Weight With Cable: 2lbs (.93kg)
Weight Power Port: .55lbs (.25kg)
Battery Terminal Ring Inner Diameter: .37” (17.5mm)
Wire Gauge Battery Cable: AWG #8
Kit Weight: 7.06lbs (3.20kg)
iWaveCube microwave? JohnF Modifications, Alterations and Updates 14 10-06-2011 08:56 PM
Using a microwave?! = NOT real... Yamaha_gurl Camp Cooking, Food & Recipes 31 07-27-2011 04:40 AM
Punishing my microwave ronsmith100 General Chat 1 02-11-2009 06:11 PM
Microwave in a 16 SD??? Legacy Posts Camp Cooking, Food & Recipes 5 10-02-2002 08:01 AM
