08-30-2012, 05:54 PM
Trailer: Scamp fifth-wheel
North Dakota
Microwave question
Our 19' Scamp has a cabinet with an outlet that can be used for a microwave. Does anybody know whether a "regular" microwave can be used, or whether you need a special one for a camper (thinking of the jostling that comes with driving it around)? And if a regular one can be used, how does one secure it--brackets, etc--and where can the hardware be found? Thanks!
08-30-2012, 06:18 PM
Trailer: U-Haul 1985
Most people have regular microwaves. You can keep them in place while traveling with bungies or lockdown brackets (you can purchase online or at camper stores).
08-30-2012, 06:24 PM
North Dakota
Thank you!
08-30-2012, 06:35 PM
Trailer: U-Haul VT
Indiana
You can get 700 watt ones for $50 to $80 . Ours is a simple one that works fine when we are on the grid. I did not size my inverter to take the old when we are off the grid and on solar. You can fabricate clips to hold it and bungees work well.
Michael J.
08-30-2012, 06:37 PM
Trailer: U-Haul VT
Indiana
Old is supposed to be load (cursed auto spell check on this tablet)
08-30-2012, 07:15 PM
North Dakota
I know--I have the same auto spell-check problem on my iPad. Love the device, but it has no brain. We have a microwave we bought for $10 at a second-hand store that is the right size for the camper, is in good shape and works well. But we're also asking ourselves if we want to cross the line from non-microwave camping to microwave camping. (Too fancy for us? But so convenient!) We plan to take a year to be full-time in the Scamp after we retire, and we're thinking it's definitely worth thinking about when that happens.
08-30-2012, 09:59 PM
Trailer: 1993 Bigfoot 17 ftCB / 2003 Honda Odyssey
Microwave mounting?
I just posted the way I installed mine in my Bigfoot 17CB.
See: <http://www.fiberglassrv.com/forums/f56/installed-microwave-oven-in-bigfoot-17cb-54024.html>
Good luck.
Mike
08-31-2012, 06:06 AM
North Dakota
My husband talks about wanting to hang ours above the table, so this is helpful for us to consider. Thanks!
08-31-2012, 08:15 AM
Cheri
The PO of my S19 removed the cabinet door over the frig. and placed a small conv. microwave in the cabinet. They cut two wood strips 3/4" x 1.5" the depth of the cabinet and attached them to the bottom of the microwave. The two strips raise the MW so it's door clears the lower cabinet lip. The strips also help keep the MW from sliding around in the cabinet. Small pieces of foam would also help stablize the MV if needed. It has not bounced out of the cabinet and works great.
Eddie
08-31-2012, 08:40 AM
North Dakota
That makes sense--didn't think about needing to raise it above the lip. I like the idea of using that cabinet space; but is there also a lot of space lost at the back?
08-31-2012, 08:57 AM
Depends on size of microwave but there is some space lost in the back. We slide the MW toward the front of the trailer in the opening and that gives us a narrow opening to the rear which we place narrow rubbermaid trays in for holding keys and change.
The big thing is the MW has a home. In another trailer we have to store the MW for transit and that is really a pain.
Eddie
08-31-2012, 09:05 AM
North Dakota
That's helpful. We haven't measured yet, but I'll bet ours is small enough to allow that "reach back" space, too. Those Rubbermaid trays are SO helpful in so many places in the camper! By the way, what do you use as a "pantry" in your 19'? We put our clothes in Rubbermaid totes and store them in the space where the fridge was in our 13'. I've thought that that would be a good space, but it's currently taken. We put most things in the cupboard under the sink, but that's pretty limited.
08-31-2012, 09:10 AM
I see RV microwaves advertised on line. I wonder what the difference is supposed to be? It sure would be nice if someone made a 12 VDC microwave.
08-31-2012, 09:34 AM
North Dakota
I don't know the difference between RV microwaves and regular microwaves--the cynical side of my nature would say "price."
08-31-2012, 10:14 AM
A 500 watt microwave would need a current of over 40 amps. Raz
08-31-2012, 10:29 AM
A 1200 W inverter would require 100+ amps. But that is what I plan to install to run a microwave. I will put the inverter as close to the batteries as possible.
08-31-2012, 10:33 AM
If I'm not mistaken I think Norm did that?
Turns out that someone does make a 12 v. microwave. Pricey for sure.
Portable Dual Powered Microwave Oven PNP-411
08-31-2012, 11:16 AM
Trailer: '98 BURRO 17WB
Delaware
However you secure your m-wave, if it has a carousel, the glass plate will also benefit from being battened down on the road. I use a couple of scrap ethafoam blocks of no particular provenance or distinction other than that they are of a dimension to serve as hold downs.
jack
08-31-2012, 11:30 AM
Trailer: 2015 Escape
Our Egg Camper came from the factory with a microwave. It's hung in brackets under the kitchen side cabinets above where the cooktop goes. And I second stabilizing the glass turntable. We've had the microwave door come open when travelling. We take the turntable out and stash it for travel. We use our micro a lot since our trailer is all electric.
08-31-2012, 02:56 PM
Originally Posted by P. Raz
OK they do make a 12 VDC microwave. A couple of observations though:
No power rating
Very small
Very expensive
I'm thinking a $100 inverter with a $50 microwave is a better plan. Cheaper too.
