Mildew AND rot - Fiberglass RV
Old 08-04-2012, 12:02 PM   #1
Trailer: 1973 Love Bug '13
Mildew AND rot
I am totally freaking out. it was bad enough to find the 12" strip of rotten wood the entire width of the trailer but now after taking our the back benches I find mold. I only see it on the under side of the fiberglass benches but the water leak has clearly run from the back all the way to the wheel wells. I knew there would be work to do but now to get rid of mold and try to fix this floor. I'm stuck. Maybe I just need to take a break for the rest of the day.
Pictures here -
https://picasaweb.google.com/1122327...YRottenRearEnd
The only saving grace might be that the rotten floor is the raised part under the dinette. If we have to replace flooring is it possible to just replace the floor to the step up? the raised floor under the dinette?
Should I go ahead and take it to the "trailer man" for inspection and evaluation Monday or should I figure out what to do about the floor first.
cathy
Cat futrell is offline   Reply With Quote
Old 08-04-2012, 01:49 PM   #2
Roy in TO's Avatar
Figure out what you need to do to the floor first. You can replace just the rear portion, chances are you may have to replace the other portions as well.
The same thing for your bench supports. Both are part of your "unibody frame". Have a look at what others have done to replace their floors. Research, make a decision then do it. The job looks bigger than it is.
« lock? | canopy »
Mold, Mildew, and old foam Bill K Jr Care and Feeding of Molded Fiberglass Trailers 7 04-09-2012 05:42 AM
Black mold & mildew jrnutpaul Care and Feeding of Molded Fiberglass Trailers 4 09-26-2008 12:27 PM
Mildew in hard to get places Isaac M Care and Feeding of Molded Fiberglass Trailers 12 06-02-2007 01:41 AM
Cleaning mold/mildew Rick and Shannen Care and Feeding of Molded Fiberglass Trailers 7 02-27-2006 09:31 PM
Cleaning mold/mildew General Chat 0 12-31-1969 07:00 PM
