Mini-Vent - Fiberglass RV
Old 12-28-2007, 01:11 PM   #1
Trailer: Burro 17 ft Widebody
I admit it, I'm in a quandary. The Burro bathroom has an Elixir mini vent (nominally a 9" square size in a 9.5" square cutout). Bigger vents will not fit, and Elixir seems to have a monopoly on this size.
I could replace it for the second time, but it appears to be a never-ending cycle. Apart from finally springing a leak, the originally "Polar White" reliably changes to "Sahara at dusk" within about a year. Actually it is a piece of junque. I could rework it, paint it with plastic paint, etc. but that would probably cut the light transmitted by a fair piece.
For a king's ransom I could order a hatch from West Marine, but the opening mechanisms appear to be more cumbersome, especially with a screen in place.
I can pretty easily make a skylight and look for a power vent for the wall or some such solution. Question: does anyone have a bead on a replacement from another manufacturer that has more of a build quality to it? Maybe an OEM for one of the current trailers which does not show up on the retail market?
Old 12-28-2007, 06:57 PM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
Per, for my money I went with the fantastic fan. It means cutting the hole bigger, but you'll appreciate the extra air flow.(providing you have power there)
Trillium used to have the small vents, but in metal
Joe
Old 12-28-2007, 08:20 PM   #3
Talking
Per,
Have you contacted Reace at Escape?
Standard Roof Vent in Bathroom
My old eyes judge that to be your size, but I could be wrong.
Old 12-28-2007, 08:27 PM   #4
If you go with any plastic-type vent again... I'd suggest painting it BEFORE the first installation, especially since you know the plastic doesn't age well. If you paint it, it should last a number of years.
Old 12-28-2007, 08:56 PM   #5
Joe: Unfortunately the roof curves drastically on two opposite sides of the vent. Putting in a Maxxfan where the FantasticFan is now would free it up for bathroom use, but no way will it fit.
Frederick: It looks right to me too. I'd better contact Reace.
Donna: Apart from the diminished amount of light, I'd paint it, and you can bet I'd do it before installation. In fact, I'd paint it on the inside too. I even went on a couple of Yurpeen sites to see what they have, with no luck.
Old 12-28-2007, 10:11 PM   #6
Gina D.'s Avatar
WHAT are you doing in there to make it crack????
My seems fine. The color. yeah, it's a bit off.
Old 12-29-2007, 01:30 AM   #7
Color is more than a bit off alright, but I haven't quite pinpointed the source of the leak. I suspect in the hinge area.
I turn the stereo down when showering, calms me down, so I don't think I caused the leak. Any damage was done from the outside, likely by one of your flying monkeys or one of the cats from the same source.
I covered the hatch with green plastic attached with duct tape. Better looking than the hatch. Will fix this when the rain stops (about a week before Bullards I reckon). Maybe I'll do more mods on the inside for a while.
Old 12-29-2007, 12:33 PM   #8
Gina D.'s Avatar
at least it's the bathroom... could be worse
Old 12-29-2007, 06:52 PM   #9
Per, try some of the rv salvage places like RV DR. George they might have one of the old all metal vents
Old 12-30-2007, 12:23 AM   #10
I emailed Reace, and got a prompt answer (no surprise there). The vent in the Escape is the same one as that in the Burro, and he knows of no other manufacturer making that size.
So, I may go to the paint option along with modifying it to take the little fan I installed. If the reduction in the light coming through is too irritating I'll just have to construct a small additional skylight. Thanks to all for the suggestions!
Fantastic Vent and Camco Vent Cover d_wildemann Care and Feeding of Molded Fiberglass Trailers 0 06-19-2009 05:30 AM
Mini Meatloaf james kent Camp Cooking, Food & Recipes 10 10-04-2008 02:13 PM
Mini Air Conditioner? Diane Soldow General Chat 14 06-02-2006 10:32 AM
towing with GM mini van JamesC Towing, Hitching, Axles and Running Gear 5 01-10-2006 09:03 PM
can my mini van tow this? Legacy Posts Problem Solving | Owners Helping Owners 5 07-17-2003 01:57 PM
