Moisture in Scamp - Fiberglass RV
Old 11-11-2012, 05:46 AM   #1
Trailer: 2010 SCAMP
Question Moisture in Scamp
My new/used Scamp has a leak somewhere. Rain came in either from the ceiling vent or a window...I can't tell which one. Part of the cushions and my new mattress got wet. When I slept in it last nite the interior of the windows were wet. What is the best way to get the moisture out? Should I take the cushion out, put in sun and run a fan?
Thanks,
M
pageleigh is offline   Reply With Quote
Old 11-11-2012, 05:56 AM   #2
Trailer: 1973 Love Bug '13
That's what I would do.
Cat futrell is offline   Reply With Quote
Old 11-11-2012, 06:36 AM   #3
First you need to trace down the leak... if it's a leak. Is it possible the windows developed condensation during the night while you were sleeping. Breathing is an issue that causes condensation. Since you can't stop breathing, you'll need to get air movement. Open the top vent (just a tad) and a window (just a bit). Having good window coverings helps too.
Right after a camping trip (anytime of the year), I stand all the cushions up on their edges and put a Dri-Z-Air (Classic) in a plastic tub, in the sink. No dampness issues in 10 years of ownership.
Old 11-11-2012, 07:51 AM   #4
Trailer: 2010 SCAMP
Thanks Donna
Old 11-11-2012, 08:31 AM   #5
cpaharley2008's Avatar
check your window weep holes to insure their operating correctly, if not they will overflow inside.
Old 11-11-2012, 09:05 AM   #6
Trailer: 2010 SCAMP
What is a window weep hole?
Old 11-11-2012, 09:09 AM   #7
on the outside are tiny slots on the bottom outside rail for any water or moisture that collects allowing it to run down the side (creating the dreaded black marks) if these become clogged then the water in the channel will come inside.
Old 11-11-2012, 09:13 AM   #8
Trailer: 2010 SCAMP
I noticed the dreaded black marks after the rain..how do I unclog and how do I get to them? Do the black marks mean that the slots are clogged?
Old 11-11-2012, 09:20 AM   #9
No it doesnt. The black marks will often just wash off - if not if you us a 3M Marine fiberglass cleaner with a fiber cloth they will come off fast.
The weep holes you are looking for by the way may on your Scamp have a plastic square cap over them (they do on mine), that you will need to pop off the window frame in order to run some weed wacker nylon through the holes to clear them.
Old 11-11-2012, 09:22 AM   #10
Emily, get a piece of weed wacker line, or something kinda stiff that won't scratch, and run it through the holes. It's a standard maintenance issue. No biggy, just needs to be done occasionally.
Black marks oftentime mean the windows are dirty. A good wax job on the trailer will keep the dreaded black marks from staining the gelcoat.
Old 11-11-2012, 03:54 PM   #11
Trailer: 2010 SCAMP
Thanks again Donna.
M
Old 11-16-2012, 08:18 AM   #12
Trailer: Escape 21 - previously 16' Scamp
Emily,
I have a 2002 16' Scamp that had leaks which appeared to be from each of the rear side windows. I re-sealed the top of the windows and verified that the scuppers were clear but still had the leaks. Turned out that the water was actually coming in from the holes in the ceiling which are for the mounting screws of the overhead cabinets. The screws holding the cabinets were regular wood screws that apparently don't seal as well as the rivet holes. The water would travel under the Ensulite then surface below the windows. My cabinets were damaged by the water so just I just removed them and sealed the holes with silicone. This is temporary fix till I get around to patching with fiberglass.
I wouldn't think that your 2010 model would have this problem, but just sayin'.....
Cheers,
Charlie
cvanzan is offline   Reply With Quote
Old 11-16-2012, 09:28 AM   #13
Chas I think you are going to find that with time all the rivets/screws can develop leaks and at some point in the trailers life will need to be reset. I am aware of a couple of pretty new trailers that have had to have more than a couple rivets/screws reset pretty soon after build. It could be they were never sealed correctly at the factory or it could be a time and use issue. The more the trailer flexes on the road the higher the chance of a rivet/screw needing to be redone.
If the overhead bins in your 10 year old trailer were ever overloaded and the trailer spent time on rough roads that could do it. I have a 92 with rear bins and funny enough as far as I know the screws holding them have never been reset & haven't leaked as yet but they are on my list due to their age to redo one of these days. I also know the trailers full history so I am aware that in its first 15 years of its life it didn't travel a fraction as far as it has traveled with me in the past 5 years or over anywhere near some of the road conditions I have taken it. ;-) I did have to reset the awning bolts though that where hidden inside the bins though and I know that it wasnt the first time those had been done. I have also had to replace a good number of other rivets though over the past 5 years - some just loose and a couple snapped in two due to fatigue - that happen to two rivets near the end of one 3500 mile trip last year. It also wasnt the first time for one of those rivets either - I had redone it about 3 years ago. I wouldn't have much in the way of cabinets left in the trailer if I was to just remove the cabinets each time a rivet/screw failed instead of just resealing them correctly.
Old 11-16-2012, 01:10 PM   #14
Carol,
It's good to know that all these things can be fixed and I do enjoy working on the Scamper.
Beside the fact that the cabinets were ruined by the water, I got rid of the overhead cabinets because I don't like the idea of having any weight up high in the rear of the trailer. Coming from an 8' tent trailer, the 16' Scamp has WAY more storage than I'm used to.
Cheers,
Charlie VZ
Moisture Dripping from Below Rear Window fusedlight Problem Solving | Owners Helping Owners 8 08-17-2012 09:52 AM
Moisture under cushions? Brian Bran Problem Solving | Owners Helping Owners 15 05-04-2011 01:29 PM
