Moisture problems - Fiberglass RV
Old 09-21-2019, 10:43 PM   #1
Trailer: Scamp 19 D 5er
North Dakota
Moisture problems
What do others do about moisture in the camper when it rains for several days? We were out for a few days with lows in the 40's and rain. Condensation was heavy on the windows most of the time. We don't have a max fan or anything in our 5er. How do others handle this? We used a portable electric heater during the night. Thanks for any ideas.
J. Sully is offline   Reply With Quote
Old 09-21-2019, 10:55 PM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
John, it sounds like you had electric at your camping site. Many use a small dehumidifier and let the water it removes from the air, just run down the sower drain. Installing a MaxxFan is the way to go in my opinion. I have had both the MaxxFan and the Fantastic Fan.
Dave & Paula
Old 09-21-2019, 11:13 PM   #3
Crack a window or two.
That allows the moisture to escape.
Alternative is to stop breathing.
Old 09-22-2019, 11:37 AM   #4
+10 Buy an RV sized dehumidifier. Amazon sells several of them.
Old 09-22-2019, 12:57 PM   #5
North Dakota
Thanks guys. I have been thinking that a dehumidifier would help. Any thoughts on a which one is best? We have a 1999 Scamp 5er.
Old 09-22-2019, 01:04 PM   #6
North Dakota
Thanks guys. We have a 1999 Scamp 5er and it is hard to crack windows open in the rain. What dehumidifier seems best? Anyone have experiences on which one?
Old 09-22-2019, 03:49 PM   #7
If you're always be connected to power then a small electric dehumidifier would work. If you're going to camping without power then I like Dri-Z-Air.
Old 09-23-2019, 09:37 AM   #8
Our solution was to go to our local marine supply store and buy a Marinco Day/Night solar vent (powered with battery back-up for 24 hour service cockpit extraction). It comes in white or stainless. Ours is model N20803W.
Installed it over the table/double bed and it works like a charm. Because it is intended for boat use, it has a high collar and baffles to keep out water and sucks out all the moisture. Plus it works 365/24/7 keeping out the moisture during storage.
Not as inexpensive as a dehumidifier but it is worry free 24/7 and removes the need to empty.
Nicolas is offline   Reply With Quote
Old 09-28-2019, 11:19 AM   #9
Trailer: Burro
What a great idea, Nicolas!
Any chance you can post a picture or two of your install, so we can better visualize this solution?
Rebecca D is offline   Reply With Quote
Old 09-28-2019, 11:38 AM   #10
Trailer: boler
Did you leave the original roof vent in, and put this is as additional venting, or did this replace the roof vent? I am looking for options to replace my broken roof vent, but don't want a noisy fan, I am a very light sleeper.
Nancy F is offline   Reply With Quote
Old 10-01-2019, 03:06 AM   #11
Trailer: 2017 19' Escape
Everywhere
The problem with electric dehumidifiers for small trailers is that they come in two types: Thermoelectric ones that aren't powerful enough to actually keep up with more than one person's humidity increases, and compressor-based ones that are expensive, noisy, and bulky.
If you can get away with just ventilating, that's the way to go.
Old 10-01-2019, 09:54 AM   #12
Trailer: boler
Thank you, we usually leave a window open when sleeping, and have replaced the original vent with one that has a fan.
Old 10-01-2019, 10:27 AM   #13
jerrybob's Avatar
Trailer: casita
These work great....been using one for years in our trailers and before that....a boat. We live in very wet country....I have one of these plugged in during the whole winter when trailer is in storage. No water to be emptied....easy to use. Some will say they don't work.....they do...no noise....cheap to operate.
https://www.amazon.com/Davis-Instrum...9947051&sr=8-6
jerrybob is offline   Reply With Quote
Old 10-01-2019, 10:44 AM   #14
If there is no water to be emptied, where is the water?
A 60 watt light bulb will also warm the air, allowing it to hold more moisture. A friend with a tug boat gave me his Davis. I eventually tossed it out, replacing it with Dri-Z-Air containers and crystals. I empty the containers every couple of weeks.
Old 10-02-2019, 07:56 PM   #15
jerrybob's Avatar
Trailer: casita
It's magic Glenn. Like I said....some folks say these do not work. They do....have been using it for years....my trailer stays dry and moisture free all winter long....I like not having to check or empty the water. Glad you found a solution that works for you.....stay dry my friend.
Old 10-02-2019, 08:21 PM   #16
Everywhere
It's a difference between maintaining in storage vs reducing humidity to counteract a moisture source.
If it's in storage, you only have to reduce humidity a little then maintain it. In a cool but mild climate especially, a heater like the Davis one will keep relative humidity low enough. Might not be a good idea in a hot climate, but a bucket of desiccant will do the job well in that case.
If it's in-use, you have to actively pull out something like half a liter of water per person per day from the air just to maintain humidity levels. A heater alone won't do, since it only lowers relative humidity a little. Desiccant won't work unless you replace it unreasonably often.
If it's hot out and you're using the trailer, the air conditioner is a very powerful dehumidifier and will be plenty by itself.
If it's cold out and you're using the trailer, letting a little outside air in will bring humidity down to outside levels then heating it up will lower relative humidity even more. So, as long as it's chilly it can help to let in outside air even when it's raining.
The hardest weather to deal with in terms of moisture is mild and humid, like 60F and over 80% humidity. Basically, Florida. I ended up running the A/C during the day instead of running the vent, just so it would pull enough water out of the air and keep the humidity down.
Old 10-02-2019, 08:28 PM   #17
I just recently read where some guy posted about condensation when he doesn’t have power, he wipes the windows with a shammy like you use to dry a car, then rings it out, out side. He said it makes a big difference, worth a try I guess ...??
Rnupnorthbrrr is offline   Reply With Quote
Old 10-03-2019, 05:11 PM   #18
Trailer: 1987 Bigfoot B-17'
We use chamois “towels” in the morning to wipe down the windows. Then turn on the maxx fan if appropriate.
Glass House is offline   Reply With Quote
Creative moisture reduction ideas for camping in a fiberglass trailer? Nelmes Problem Solving | Owners Helping Owners 28 02-02-2015 06:59 PM
Is it a leak or moisture issue...or both? Otters Problem Solving | Owners Helping Owners 22 02-23-2013 05:08 PM
Moisture in Scamp pageleigh Problem Solving | Owners Helping Owners 15 11-17-2012 12:07 AM
Moisture Dripping from Below Rear Window fusedlight Problem Solving | Owners Helping Owners 8 08-17-2012 09:52 AM
Moisture under cushions? Brian Bran Problem Solving | Owners Helping Owners 15 05-04-2011 01:29 PM
