Molding Sliding - Fiberglass RV
Old 04-11-2017, 03:34 AM   #1
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
Molding Sliding
The Tee Molding in my 79 Boler 1300 is sliding out of shape in spots.
On the ceiling, going all the way from front to back, where it once was cut and touching the front window gasket, there is a 2 inch gap and on the same piece, toward the back it has puckers in it.
The ensolite is well stuck to the shell so I do not want to compromise that in any way but how can I fix this problem?
Old 04-11-2017, 05:16 AM   #2
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Some people have had luck reshaping it by boiling it in water. I was missing some in the Trillium I rebuilt, and just bought new stuff. It is not very expensive.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 04-11-2017, 03:46 PM   #3
Maine
Thanks Jim, I really do not want to take it down as it may start the ensolite to fail at the joint.
Didn't know if anyone has just tried some way to get it to slide back in to its original place.
Anyone?
Old 04-11-2017, 03:53 PM   #4
John in Michigan's Avatar
Gerry, some of the T molding in my Trillium 4500 was wavy (puckered) so I removed those pieces and put them in a pot of hot water (about 200 degrees F) for 20 minutes. This eliminated the waviness. Then I re-installed them.
PS: Removing and re-installing the T molding hasn't caused any problems with my ensolite.
Old 04-12-2017, 02:24 AM   #5
Maine
Maybe I'm over estimating the difficulty of the removal of the T molding.
I am more comfortable doing the more technical things such as wire / water / gas then simple things so maybe I'm thinking too much.
I will investigate the ease of removal and or movement of it today.
Thanks
Old 04-12-2017, 02:58 AM   #6
Borrego Dave's Avatar
Thanks
Had to chuckle Gerry, I know where you're coming from. I've over estimated the difficulty on a number of projects over the years only to find afterwards I spent more time with that than it really took doing the job....lifes learning experiences . I remember my Dad telling me not to be afraid to try it....there's always somebody that can fix it. In over 50 years I've only had to call in the cavalry a couple times .
sliding cushions Scott S. Modifications, Alterations and Updates 5 09-09-2008 09:58 AM
Sliding rear window Pat C Problem Solving | Owners Helping Owners 3 05-27-2008 04:35 PM
FOUND - Wanted : Rear side sliding window for Scamp DanPatWork Classified Archives 1 08-08-2007 08:34 PM
Sliding window mouldings Manitoba Paul Problem Solving | Owners Helping Owners 5 06-17-2006 07:14 AM
Cleaning the drains on Hehr Sliding Windows Legacy Posts Problem Solving | Owners Helping Owners 5 01-06-2003 05:04 PM
» Trailer Showcase
Violet
Tara_B
Scamp 13'
chse
