More U-Haul Questions... - Page 2 - Fiberglass RV
Old 12-08-2006, 11:29 AM   #15
Trailer: 13 ft U-Haul
Okay, thanx again for all the replies and info.
Now I just have one more (VERY IMPORTANT) question about wheel bearing replacement.
I've done enough research to find out that these U-Haul campers have a Dexter torsion axle with permanently sealed bearings. For my own peace of mind, I'd like to replace the NEV-R-LUBE bearing cartridges on each spindle.
My question is.... What size NEV-R-LUBE cartridge is used on the U-Haul campers?
I know that there's three different sized cartridges (35mm, 42mm and 50mm), and wouldn't expect it to be the largest of the three. So would it be the 35mm or the 42mm???
Does anybody know for sure??
I'd like to order them right now so I can replace them when I pick up this trailer.
Here's the site that has the NEV-R-LUBE bearing cartridges I'm referring to....
http://www.lowcosttrailersupplies.com/Merc...ge=LCTS/CTGY/RB
Buck62 is offline   Reply With Quote
Old 12-08-2006, 12:54 PM   #16
Brian B-P's Avatar
I''ve heard that U-Hual used some odd sized parts on their trailers, but are the rims a "standard" 5-hole 13" rim?
Just about everything you wanted to know about U-Haul wheels, and likely more, in one topic:
[b]tires n rims, 14 inch
u-haul
U-haul Value? Chet F General Chat 2 04-24-2007 06:00 PM
Old U-Haul John Perry Problem Solving | Owners Helping Owners 7 10-01-2006 05:15 PM
U-haul Terry G. General Chat 3 09-24-2006 06:21 AM
Replacement windows, questions, questions. CliveAlive Modifications, Alterations and Updates 4 07-13-2006 07:32 AM
Brakes for U-Haul? Jim C. Towing, Hitching, Axles and Running Gear 21 12-02-2005 06:27 AM
