Mounting a flat screen tv in a Burro - Fiberglass RV
Old 04-04-2009, 04:27 PM   #1
JMS
JMS's Avatar
Trailer: 1983 13 ft Burro
We have a rehab'd '83 13 ft. Burro and would like to mount a 19" flat screen tv on an articulating arm mount. The only place I can see to mount it is on the front exterior wall over the bunk beds but I don't think the fiberglass shell will support it. Does anyone have any ideas on how to accomplish this?
JMS is offline   Reply With Quote
Old 04-04-2009, 04:57 PM   #2
pjanits's Avatar
Trailer: 17 ft 1986 Burro
How about mounting it from the end of the cabinets over the sink or the closet? Use some wood backing and it should work ok.
Old 04-04-2009, 08:50 PM   #3
CindyL's Avatar
Illinois
The hubby is about to attempt the same thing on our Uhaul. Maybe if it works, he will post how he does it.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
CindyL is offline   Reply With Quote
Old 04-04-2009, 09:22 PM   #4
curtis c's Avatar
Trailer: 1994 Lite House
pics! just use a rack made for a wall and put plywood behind the fiberglass and in front and sandwich it together to take the strain off the holes where the bolts go through. and allways take it off when you travel. so like this mount[plywood]fiberglass wall[plywood] and run the bolts all the way through. plus a 19 flat screen is light. i agree with putting it on the closet or above the sink. if you have a problem you wont be worried about the elements getting in while you fix it.
curtis c is offline   Reply With Quote
Old 04-04-2009, 10:45 PM   #5
Raya's Avatar
I bet he's wondering how to get to the back of the screws (bolts) to get the nuts on though. That would be the challenge, I would think, on a Burro (at least on the wall by the bench -- the closet or galley cupboard wall you could reach the backside on).
R.
Old 04-04-2009, 11:02 PM   #6
Alf S.'s Avatar
Hi: All... Those 19" flat screen TV's weigh 10-14 lbs. and the pull on the arm would be a lot!!! Try holding a 10lb. bag of flour up with your arm extended out!!! Lots of reinforcing req'd. Our local RV. dealer charges up to $500. to add reinforcing and a swing arm for a flat screen TV.
Old 04-05-2009, 06:22 AM   #7
JMS
JMS's Avatar
That was my intent to mount it on the end of the cabinets but the projection of the range hood blocks the view. Hanging it on the side of the closet is possible but it makes it hard to view when laying in the bed. The only other option I can think of is using a ceiling mount with a couple stainless steel plates or.....just set it on the top bunk as we did with the crt unit unless I can find a longer articulating arm that would project past the range hood.
Old 04-05-2009, 07:35 AM   #8
Trailer: 2009 Scamp 16 ft / 2014 Ford E-250 cargo van
Did you look at Ram Mounts = http://www.ram-mount.com
I have used one on my Boat for years to hold a laptop.
Bill K
burro
Screen door for Burro Legacy Posts Modifications, Alterations and Updates 28 06-18-2012 04:40 PM
Installing a flat screen TV - how to get wiring to it? Carol H Electrical | Charging, Systems, Solar and Generators 23 06-20-2011 02:58 PM
screen door on Burro ThomasE Care and Feeding of Molded Fiberglass Trailers 1 08-11-2009 02:27 PM
Screen window on Burro Bill Rinaldi Problem Solving | Owners Helping Owners 1 07-01-2008 03:50 AM
Mounting an Awning on a Burro (double shell) S Sato Modifications, Alterations and Updates 17 03-05-2006 08:16 PM
