My Boler Kitchen Cabinet sags...does yours? - Fiberglass RV
Old 03-27-2012, 01:46 PM   #1
bomni's Avatar
Name: Matt and Lindsey
Trailer: 1972 Boler 1300
We are restoring our '72 Boler and have just put the lower kitchen cabinet back in. After replacing it we noticed it sags in the middle, at the back between the stove & sink. From the original rivet placement it looks as though it has always been this way, it is quite pronounced though and I'm wondering if this is normal or not? Any other Boler 1300 owners noticed this?
bomni is offline   Reply With Quote
Old 03-27-2012, 07:02 PM   #2
The only time I can remember when someone talked about a cabinet sagging, it was being pulled down at the rivet area because the roof was starting to sag. Think of your trailer like an airfilled ballon. Push down on the top and the side starts to bulge. Sorry I can't be more help...
Old 03-27-2012, 11:20 PM   #3
bomni's Avatar
Thanks Donna for the suggestion, I don't think the roof is sagging since the two outer rivets are much higher than the middle two rivets. Our door fits very well and besides a couple very small cracks in the upper right hand of the door, there are no signs of sag. It looks like it has always been sagged in the middle, but it seems unusual which is why I'm curious if anyone else has noticed this. Maybe there is some reason that I'm missing...Matt my hubby can't make heads or tails of it either. We are putting a wood countertop over it & I want to be sure that we aren't overlooking something...
Old 03-28-2012, 05:35 AM   #4
Lindsey, why not change the rivet position then? Jack up the area of the sag (carefully) then rivet in the correct place. If it doesn't pull too hard it may stay in place. Fill the non-rivet hole and go camping!
Old 03-28-2012, 02:24 PM   #5
bomni's Avatar
We actually covering it with a wood countertop and so won't see it at all (But I will know its there and wonder)...oh well next Boler owner I meet, I will remember to ask them...I just though perhaps one of the Boler owners here would be of help.
Old 03-28-2012, 06:14 PM   #6
Jeff Richardson's Avatar
Trailer: 1977 13-foot Scamp
The lower kitchen cabinet on my 1977 Scamp sags badly in the middle, especially along the wall. I recently sighted down the row of rivets on the outside and it looks like they dip down in the middle like yours.
I have been planning on putting a plastic laminate counter top on to cover the sag. Now I'm thinking I will probably re-drill for the rivets to straighten it out but I still want to put a plastic laminate counter top over the top for easy clean-up when cooking. I will probably put shims under the plywood I will use for the counter top to help support it.
I've looked at lots of pictures of Scamps for sale on the internet and haven't seen any that sag as bad as mine.
Jeff
Jeff Richardson is offline   Reply With Quote
Old 03-28-2012, 11:11 PM   #7
bomni's Avatar
We just put our wooden counter top tonight, the sag in the middle is two inches give or take. We debated on what to do, because the rivets are lower in the middle and additionally the fiberglass & wood support underneath at the back of the stove area sag even further. We shimmed it, also propped it a bit with a jack and secured it to the new countertop with screws.
Thanks for letting us know that we aren't the only ones with the wonky cabinet...I was beginning to wonder if we were just unlucky! Maybe there is some reason for the lower rivets, but I really don't get it.
Old 03-29-2012, 11:44 AM   #8
james kent's Avatar
Trailer: Boler 1984
Yes ours sags in the middle. At least it did before I replaces the divider between the fridge and the wheel well area and braced the back edge along the wall. If you are going to replace the top, why not cut out the centre section of your existing top to rid it of a couple of pounds. Just leave enough around the edge for attaching the new one into place..
Old 03-30-2012, 11:34 PM   #9
bomni's Avatar
We though about cutting out the top but want to leave it 'just in case' we ever decide we want to restore it...probably never will, but you never know with us! We didn't have a divider between fridge & wheel well, but thinking about it a divider might be a good idea in the future and also some extra support for the sag.
Old 03-31-2012, 01:37 PM   #10
Mike Magee's Avatar
Trailer: Li'l Hauley
Just get a little older like your Boler did, and your body sag will offset the cabinet sag...
In the '60s, people took LSD to make the world seem weird.
Now the world is weird, and people take Prozac to make it seem normal.
Old 04-01-2012, 12:52 AM   #11
bomni's Avatar
If I sag that much I will be finding a good cosmetic surgeon!!
boler
Is the kitchen cabinet support needed? Newfang Modifications, Alterations and Updates 31 03-14-2017 01:15 PM
Sigh . . . Five Scamp Upper Kitchen Cabinet Doors peterh Modifications, Alterations and Updates 30 03-11-2011 06:19 PM
Organizer for upper kitchen cabinet peterh Modifications, Alterations and Updates 22 11-04-2008 04:55 PM
The Boler's new kitchen and other mods Lizbeth Modifications, Alterations and Updates 17 03-14-2008 10:28 AM
