my fridge stops working after 24 hrs - Fiberglass RV
Old 09-29-2010, 06:12 PM   #1
Ohio
Is it normal for a refrigerator (mine is relatively new) to kick off after 24 hrs when connected to the RV battery? A red light comes on, saying that there is not enough voltage needed to operate the fridge. I checked the battery with a volt meter and it reads 12 volts. Shouldn't that be enough? When I hook it up to the house on AC current, the red light goes off and the fridge works great. Checking the battery on the RV when hooked to the house, the battery reads 14 volts. Why should it work at 14 V and not 12 V? I could see it not working under 10 V but 12?
Thanks for the help...Lloyd
lloyd cicetti is offline   Reply With Quote
Old 09-29-2010, 06:18 PM   #2
Trailer: 1999 Burro
When mine runs on battery alone, the voltage coming out of the battery drops to only about 6 volts after about 12 hrs. I am surprised it lased that long
joelh is offline   Reply With Quote
Old 09-29-2010, 07:13 PM   #3
Ohio
are you saying that if the fridge worked for 24 hrs, that would be normal?
Old 09-29-2010, 07:29 PM   #4
Trailer: 1984 Scamp 13'
Maryland
Unless something has changed, 12v mode is supposed to be only for on-the-road use where it runs off of the tow vehicle's alternator, not a house battery. If you are parked, you should be running on LP or 115v AC.
My guess is that the fridge has a low voltage shutoff to protect the battery, since it is assumed that it is running off of the tow vehicle... you wouldn't want to accidentally leave the fridge on 12v and find that you can't start your tow vehicle since the battery is dead.
Old 09-29-2010, 08:26 PM   #5
Matt in SV's Avatar
The open circuit voltage measurement of a fully charged 12V battery is more than 12 volts: You'll see about 2.12 volts for each of the six cells, for a total of about 12.7 volts at rest. By the time you actually measure 12.0 volts, you'd have used about half the charge capacity, which is considered a typical "safe point" for frequent discharge and reasonable life expectancy. By the time you hit 10 volts you'll have done some damage.
It looks like your refrigerator is working correctly and trying to prevent damage to the battery.
Regards,
Matt
P.S. there is a colorful chart about 3/5 toward the bottom of this section that may be useful:
Deep Cycle Battery FAQ
Planning our next Escape!
fridge
Trailer Fridge now Working Properly Rick G Care and Feeding of Molded Fiberglass Trailers 4 07-23-2018 05:42 PM
3way fridge not working on 12V Rick G Problem Solving | Owners Helping Owners 28 03-31-2010 10:44 AM
Fridge not working on AC Parker Buckley Problem Solving | Owners Helping Owners 11 12-04-2009 09:53 PM
Fridge quit working D Tharp Problem Solving | Owners Helping Owners 7 09-23-2009 07:53 PM
Fridge not working all the time Karen Fisch Problem Solving | Owners Helping Owners 7 05-01-2006 07:25 AM
