my furnace doesn't kick in - Fiberglass RV
Old 04-05-2010, 10:10 AM   #1
Usually when I click the thermostat to the ON position and the trailer is a bit cold, the fan will immediately come on....but the heat will slowly follow. Now, with plenty of power available from my home, I click the thermostat on and nothing. Should I check the fuses? Could it be anything else? Thanks, Lloyd
lloyd cicetti is offline   Reply With Quote
Old 04-05-2010, 02:57 PM   #2
Trailer: 17.5 ft and 25 ft FB Bigfoot
It could be a number of things. Start with the easiest and progress to the more difficult. Yes fuses and breakers should be checked first. Use a volt meter at the fan to see if the fan hasn't burnt out. Check the thermostat control so see if broken, wire corroded, loose wire. You can also use a volt meter at the therostat although I don't know what voltage it should read. After that I'm afraid I'd have to call my friendly RV technician.
Tamid is offline   Reply With Quote
Old 04-05-2010, 08:06 PM   #3
Doug P.'s Avatar
Trailer: Escape 5.0TA
Southern Alberta
Some furnaces have a reset button, its normally near the front so as to be easily accessed.
Might be an easy fix.....
Doug P. is offline   Reply With Quote
Old 04-05-2010, 08:23 PM   #4
Propane turned on???
Old 04-05-2010, 09:44 PM   #5
Harry Young's Avatar
Post
lloyd
Make and model of furnace would really help.
Harry
Old 04-05-2010, 10:02 PM   #6
lloyd
Harry
Harry, I think it's an Atwood...but I will get back to you with Model No. Thanks, Lloyd
furnace
Atwood furnace new on Trillium..won't kick on...fuses fine.... lloyd cicetti General Chat 15 04-12-2010 08:21 PM
Furnace doesn't start ThomasE Problem Solving | Owners Helping Owners 16 10-13-2009 01:22 PM
Side Kick Trailers Will O'Crotty General Chat 9 03-18-2008 11:03 AM
The Louisiana Three Kick Rule Legacy Posts Jokes, Stories & Tall Tales 0 03-30-2003 08:00 AM
