Mystery Switch in Head - Fiberglass RV
Old 07-10-2018, 08:55 AM   #1
We recently purchased a 2008 21 ft front bed Bigfoot and in the head next to the toilet there is a switch whose function is a mystery to us. All of the research we have done leads us to two possible options (although there could be some other functions that we are not aware of): we think it is either a switch to change the hot water tank to electric mode or to turn on the heater for the holding tanks. Can anyone shed light on this mystery?
KBand is offline   Reply With Quote
Old 07-10-2018, 10:46 AM   #2
What about the drain pump for the shower?
Does it make any noise when switched on?
Old 07-10-2018, 12:31 PM   #3
Trailer: 1993 Bigfoot 17 ftCB / 2003 Honda Odyssey
Mystery Switch.
It is probably for the front outside light below the window to illuminate the hitch area, just above the propane tanks.
Mike .....>
Michael Pupeza is offline   Reply With Quote
Old 07-10-2018, 01:44 PM   #4
Borrego Dave's Avatar
Might be for the water pump. I had a class C with switches in the bath and kitchen, very convenient.
Old 07-10-2018, 07:28 PM   #5
Thanks for the reply, Dave. We were hoping that, however testing ruled it out...
Old 07-10-2018, 07:46 PM   #6
Trailer: Escape... exScamp 19 both great trailers
Wisconsin
Mystery switch
Shower sump. The pump is exposed under trailer and connections have a tendency to get corroded. Use a test lamp to see if you have power to the pump. Or a jumper wire to run 12 volt power direct to pump to see if it is working. My guess is you don’t have power to the pump or bad pump so no matter how many times you flip the switch nothing will happen.
Good luck
Jm Rintel is offline   Reply With Quote
Old 07-11-2018, 06:59 AM   #7
Doug Arthurs's Avatar
Mike .....>
On my 17' bigfoot the outside front light switch is next to the kitchen counter behind the dinette bench seat. Took me a little while to figure this out. I wouldn't think they would put such a switch in the bathroom.
Doug Arthurs is offline   Reply With Quote
Old 07-12-2018, 07:52 AM   #8
Good luck
Thanks - that seems pretty likely. We are dry camping and using the campground showers, but I will go under and check that.
Need help with mystery wire to water pump switch Sandstone Problem Solving | Owners Helping Owners 10 06-30-2017 09:17 AM
Bigfoot mystery switch... Whaler Electrical | Charging, Systems, Solar and Generators 8 04-28-2015 12:11 AM
It's December, Head to the Beach! brian m. General Chat 4 12-16-2007 05:01 PM
Stuck in your head Lew King Jokes, Stories & Tall Tales 7 01-03-2006 10:28 AM
Stuck in your head General Chat 0 01-01-1970 12:00 AM
