Need Casita trailer advise/comments - Fiberglass RV
Old 10-04-2015, 02:58 PM   #1
Trailer: 2001 Scamp 16 layout 3
Almost bought a scamp 16 but just could not accept compromising on a 44" bed. Casita 17 Spirit with couch/bunks in front and portapot seems like a good alternative since it has 54" bed. Will a Chrysler 3.6L Minivan pull it easily? It has a 3600 lb. tow capacity. Spirit 17 dry weight (before add AC, furnace, and gear probably totaling about 900- 1000 lbs.) is 2210 but is that cutting it too close? (Especially up and down the Rockies)? Also, what are some of the quirks/problems common with this trailer? It probably will end up a new trailer. Would greatly appreciate advise from experienced fiberglassers.
denny w is offline   Reply With Quote
Old 10-04-2015, 03:14 PM   #2
Bob Miller's Avatar
You didn't mention the year or miles on your minivan, but some of them have a reputation for having weak transmissions. I had one fail twice while still in warranty, and I wasn't towing with that vehicle.
Ask the local dealer service manager and local transmission shops about you specific unit.
At the very least, I'm sure that they will suggest adding an external transmission oil cooler.
Old 10-04-2015, 03:45 PM   #3
Jon in AZ's Avatar
Have you also checked into a Scamp 16 deluxe (wood interior version)? Same 54" bed size as the Casita, but lighter, and you don't have to give up the bathroom.
I personally prefer the side bath/front dinette plan. (The side dinette plan has a funky galley design where the stove overhangs the bed a few inches, which I don't care for, but necessary to accommodate a curbside fridge along with the larger bed. The side bath plan solves the issue by moving the fridge to the street side next to the bath.) The side bath is pretty tiny, and you could probably get Scamp to delete the toilet & shower and use it as a porta-potty closet if you preferred for even less weight and cost. It has way more galley space than the Casita. The front can be customized in several ways: storage closet plus dinette/child bed, omit the closet to make a full-width adult single bed/dinette, or sofa/bunks as in the standard version.
Old 10-04-2015, 03:48 PM   #4
Minivan is new 2016.
Old 10-04-2015, 03:52 PM   #5
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
You might want to check the average tongue weight at Trailer Weights in the Real World or download the sortable spreadsheet I keep at LakeshoreImages.. Both the total weight & tongue weight of a Casita 17 may be a bit high for a minivan - Average actual weights from the spreadsheet are 3286 total weight & 422 tongue weight...
Old 10-04-2015, 07:23 PM   #6
tractors1's Avatar
Trailer: Escape 21 - Felicity
3.6L might pull it fine, but the tow rating is also based on suspension and stopping power. I wouldn't do it - had a 17LD Casita with a 3500 lb rated Tacoma and it was marginal up/down hills although it seems to handle fair. Traded tow in for a 6400 lb rated Taco with the V6 and it made a world of difference - primarily the different gearing of the transmission. Now it tows a 4100 lb Escape 21 up and down the Rockies just fine.
Charlie Y
casita, eco
Need advise on a leaky slider Earl E. November Problem Solving | Owners Helping Owners 24 03-29-2012 03:57 PM
Need advise on new converter upgrade FredericL Problem Solving | Owners Helping Owners 9 05-14-2009 08:52 AM
My '82 Burro needs floor fixed or replaced, I need advise MikeCM Modifications, Alterations and Updates 5 03-11-2009 04:28 PM
Help! Need some advise Adrian W General Chat 1 02-27-2007 08:16 AM
