Hurrah! Finally. Post Office sent it to the wrong delivery route.
I like it. Went right up no sweat.
Will easily fit both 0 Gravity Recliners easily and then some.
Next get a clip on fan for my chair attached table and am set.
Truly fast up and down.
Screen is gray see thru.
Bottom Skirting gray.
Tent bottom portion bright green.
The hinges are double jointed so you have to turn them 180 to set the poles up. The logo goes on the outside.
For some reason? the green loops on the tent were not slipped over the poles.
No problem.
Just carefully telescope closed, unsnap black ring, take bottom stand off tip, slip on loop, then put tip back on and snap black ring.
Not necessary to do again.
The tent folds down no problem.
We can leave our recliners under the roof and take the shelter down when it rains and then slip back up again.
Definitely get you some plastic hook stakes.
Can slip the loop on and off without unstaking.
Just what we needed. Nothing fancy, just no bugs biting us.
Margaritas I taste you already.
